BMR T56 Torque arm relocation mount pics!
Old Sep 21, 2005 | 01:46 PM
96silverram's Avatar
Default BMR T56 Torque arm relocation mount pics!
I said I would post some pics of the new BMR mount for the T56 LT1 car's. The idea behind this mount is the fact you can take the stress off the tail-shaft of the T56 and place it on the heavy duty mount
Old Sep 21, 2005 | 01:54 PM
RealQuick's Avatar
Nice!
Old Sep 21, 2005 | 03:34 PM
luckyou03's Avatar
I expect it to stay that clean. Looks nice
Old Sep 21, 2005 | 06:05 PM
lt1fbody355's Avatar
What exhausts will this work with? Does it have any advantages over the trac-pak?
Old Sep 21, 2005 | 06:35 PM
I can't honestly answer what exhaust the mount will work with correctly. I do know that is was close on my FLP Y-pipe, but it did work without problems. I would assume that most Y-pipes would work as long as they are not custom 3 1/2" tubes or something similar. Some advantages I can think of with this system over the trak-pak is the fact that you can continue to use all the options of torque arms that different manufacturers make for these cars. I'm going to say buy BMR because I'm currently using the chrome-moly torque arm. I also like having this setup that is closer to factory. I had the trak-pak a long time ago and it did work well, but I did not like how much lower it sat under the car; although, I did have my car lowered about 3" at the time so maybe that had something to do with using the BMR Trak-pak I have had both setups and I think I will like this alot when I get a chance to test it out at the track
Old Sep 21, 2005 | 07:36 PM
Z284thgen's Avatar
when 2025
haha looks good lomont
might be having a cam for sale that you will be interested in real soon
Old Sep 21, 2005 | 11:48 PM
TwoFast4Lv's Avatar
Thank you for posting pics! I almost bought one. Now seeing it installed i see it has the usual problem. to damn low!
Old Sep 22, 2005 | 10:13 AM
Your welcome
