worth it? Cam, heads, headers?
Old 10-02-2005 | 12:16 AM
slagger's Avatar
Default worth it? Cam, heads, headers?
well i finally got the $$$ to do my rebuild :-) and i'm decideing cams cc305 maybe and i'm going to port & polish the heads and get the computer program. now the Q should i get the shortys ? or just leave it stock how much power is gained with the headers is it worth it?
now if i get the headers then i need the y and new exhaust $$$
do you think the stock will perform good.
i have a built A4, 3.42 gears.
thanks guys
Old 10-02-2005 | 10:12 AM
Ari G's Avatar
LT´s get you 15-30RWHP,go if you want power get 306cc or GM847,the stock headers are BAD
Old 10-02-2005 | 01:07 PM
slagger's Avatar
my tuner said no probleme passing smog with the cc305 but the cc306 might take a few tries. LT not legal here.
Old 10-02-2005 | 01:26 PM
matrik's Avatar
When your in the position where stuff is not legal... try to get a friend who can pass you .
Old 10-04-2005 | 10:01 AM
96 LT-1's Avatar
Bad Seller Warning!
where are LT's not legal? I have to pass emissions will I have a problem?
Old 10-04-2005 | 08:36 PM
slagger's Avatar
I'm in So California, you have to move the cats back for the LT my smog man say he will let me move them back alittle as long as i get the hook up.
Old 10-04-2005 | 11:30 PM
bichin95redta's Avatar
NY is adopting many of Cali's emissions inspection laws. I have been told by SEVERAL inspection techs that as long as your state doesn't use a sniffer-test, you should be okay with both the cam, and the cc306.
Go with long-tubes. I believe Kooks makes LT1 long tubes with all the emissions bungs welded on. The before-cat 02 sensor screws right in. With the aftermarket, catted y-pipe you'll probably need, the rear 02 sensors are screwed into the after-cat bungs, but left unplugged. You then plug 02 "sims" into the after-cat 02 sensor plug. This keeps you from throwing a SES.
Depending upon the state you live in, if you get a prik inspector, he could fail the car on a "visual" for not having OEM emissions-compliant parts, and for the aftermarket parts not being in the same location as the OEM parts were.
I'm gonna have to go through this s#it in March, when my inspection is due. However, I've had techs tell me they'd give me a sticker as long as the car doesn't set a MIL when it's plugged into the computer. If the computer test passes, they could give a s#it less about OEM emissions compliant parts/locations.
Check out your state's emissions inspection laws. If the test is solely based upon how the computer reads your OBDII codes, you're in like Flint....then go and get those long-tubes AND the cc306.
Old 10-05-2005 | 10:47 PM
slagger's Avatar
Ok on ebay i seen a sweet setup LT w/daul cats out the one cat is almost in the same area as stock :-)
now my Q is i only have 1 cat how do i hook up Daul cats o2 sensor?
Old 10-06-2005 | 02:44 AM
Evaporate's Avatar
Hell, we should just switch motors I have the cc305 and computer programmed and headers and it runs perfect.
Old 10-06-2005 | 06:07 PM
slagger's Avatar
how you like the cc305?
what headers you have..
Old 10-06-2005 | 06:17 PM
brandboZ28's Avatar
Id suggest MAC mid length headers. Ive had mine for 4 years and the coating is starting to wear but theyve had a hard life and held up well. You can get them with all emission hookups and even keep the stock location for the cat. In SoCal, I would be willing to guess that theyre strict on emissions so I wouldnt even test the waters. Im also guessing youre car is a 93-94 since its a single cat car. You could convert it to dual cat but why? As for the cc305, I ran it for a lil while and it ran hard! I ended up going bigger but would suggest that cam for a daily driver anyday.
Old 10-06-2005 | 07:35 PM
Evaporate's Avatar
I like it a lot because drivability is great, it passed smog twice now, good gas mileage for a mildly- sized cam v8, nice upper rpm pull, noticeable lope at idle when I had my loudmouth exhaust, and great mpg on the highway. I have slp dual cat shorties. I was planning to keep this setup, get the heads ported, and go with a blower, but I couldn''t resist on an NA cam that was for sale. I'm gonna throw in a used Joe O cam that's in the 226/234 range and will likely swap these shorties out for the rk sports sitting in the garage.
Old 10-07-2005 | 11:12 PM
slagger's Avatar
on the single to daul cam how would i run single and try to keep the cat around the same location? i'm thinking i would have to put the cat after the Y
thats one reason i was thinking about getting LT a few people told me its not that much more HP from stock to shortys?
i don't know.
Old 10-08-2005 | 04:11 PM
'95's were single cat, too. I think the switch to dual cats was in '96, at least for F-bodies. My '95 Trans Am was a single cat, although this could fall under one of the "mid-year" changes.
Anything is better than stock exhaust manifolds. Shorties do offer the advantage of not moving everything so far back, allowing OEM emissions hook-ups/location. I'm not sure about whether or not mid-length headers allow the same.
Strictly from a power gain viewpoint, nothing will out-perform a set of well-designed and manufactured long-tube headers. They scavange cylinder exhaust better than anything else, hence their better flow characteristics. Combined with CAI, heads, and a cam, you can make a kick-*** LT1. BUT....thoroughly research your state's emissions testing regulations. Depending upon the regulations, long-tubes may not be an option.
Quick Reply: worth it? Cam, heads, headers?
