Roller rockers # 50
I am saving up now for these
http://www.cranecams.com/index.php?s...&lvl=4&prt=108
1.6 roller rockers..
Just wanna make sure these are good and i need to know what else am I going to need? what kind of springs?
no one need to tell me what other mod i need to get. This is what im getting.
Comp cam pro magnum rockers are a better buy
you can get them in a 7/16" stud....then buy ARP 7/16" screw in studs too match
they are lighter at the valve tip, stronger throughout the body, rebuildable and not aluminum (chromoly)
and if i'm not mistaken, about $25 cheaper....
If you're just doing the rockers, the LT4 springs will work just fine and they're cheap. If you plan on doing a cam down the road w/ dimensions bigger than a Hotcam, K-Motion K800's should handle whatever you decide on.
