LT1 questions
I have been reading the posts here for a few days...I am actually putting this in a 64 chevelle! I have been around a bunch of big blocks and few built SBC! But I have never done much with LT1's so I thought I would ask the guys that know! I am not looking for a crazy amount of power just want it to sound nice and run good! The car will also have T56 and 9in rear probably 4.10 gears
This is what I was thinking....
58mm throttle body(probably Holley)
Comp cam 07-467-8
http://www.powerandperformancenews.c...Category_Code=
30pd injectors
minor porting(intake and heads)
1.6 Roller rockers
mid lenght backswep headers
3in exhaust(spintech mufflers)
a pcmforless tune or possibly speedinc.com tune not sure yet?
If I am missing something or there is something that would do better???? I open to suggestions?
Thanks in advance?
I have to go with midlenghts......ground clearance!
The car is on air ride and the crossmember sits on the ground! I know longtubes would be better but I just can't run them!
crossmember on the ground...longtubes smashed or dragging on the ground....long tubes for an a-body hang down 2-3 inches lower than the crossmember
cannot do long tubes if I need to downsize in throttle body I can but I can not do long tubes!
any head suggestions?????
I have looked at his site a couple times how do his heads compare to say Trick flows or AFR's ????????
http://www.trickflow.com/product/che...t1_airflow.asp
here is the flow numbers on the Trick Flow Heads that doesn't seem real good? Or is it for an LT1? I can get these for a little or 1k
