electric water pump?
Thanks a bunch
as for difficulty, its not hard to install. you do have to press a small brass cap in your stock housing which is alot easier with a press. other than that its just wireing it.
you can leave the cam gear drive that ran the old pump alone. If not you'll have to remove timing cover, and pull the cam gear to get it out. Not hard, just a few more minutes of work.
Note, he'll only have to cut the fan shroud if he installs a Meziere. The CSR only sticks out a couple inches. When I had mine, it came close to the fan shroud, but didnt touch it.
This should cover you for the install. Summit Racing had the CSI pump also part # CSI-901LT1, $169.95 plus 8.95 handling fee. Scoggin Dickey is $150 now plus $12.75 shipping.
Its a very easy install.
Just be safe and take it out while your there
