LT1 swap A/C Traction harness questions
Everything is from a 94 Camaro. I have a 4l60E trans. I do not plan on using the A/C or traction control features of the PCM in my swap. I am unsure of what to do with the wires for these circuits so I do not set any codes. I believe I can leave the outputs disconnected. I just don’t know if anything needs to be done with the inputs.
The wires and their functions are listed below.
C13 performance mode switch signal
A12 electronic brake and traction control module TP sensor signal
A23 traction control system spark retard request
C11 traction control system "active"
D24 A/C evaporator temp sensor signal
D12 A/C refrigerant pressure sensor signal
B1 A/C request Signal
B21 A/C clutch status
Thanks for the help
Mike
Thanks for the help
Mike
