What kind of rwhp and times does a good-running CC305 cam car get?
Im looking to maybe buy a 95 Z28, it has a CC305, it's untuned and has stock manifolds. What kinda rwhp, times does a good running CC305 cam car get? thanks
New clutch, flowmaster exhuast, dist assembly, starter, cc305 cam, pro 5.0 short shifter, 2 inch lowering springs, new tint, underdrive pullies, air foil, new struts, rotors, brakes, timing chain, valve job, push rods, water pump,
Originally Posted by brandboZ28
Thanks. The main advantage that I had was the headers. Stock mainfolds suck bigtime for flow. That and a good tune should be one of the first things Id look to get.
this thread makes me feel good about my CC305 sittin in the garage can't wait to get it in the 4 door
Edit* specs on mine if you're curious:
CC305, 1.6 RR, vortec elbow, msd 6a with 8.5 plug wires, shortie headers, and a 125 compucar wet shot. theres something i am forgetting, but everything is still apart right now.
I am getting ready to install a cc305 next weekend. I am hoping that it will liven up the car a lot. I am going to use this cam with 125 shot of NOS. Anxious to see what kind of times I will be able to get with her.
Originally Posted by Cahill93Z28
yes those are all things im taking into consideration. There is know one is KC that does LT1 edit, so should i just go mial order?
With that setup though, you could probably get a Madwolf tune, or try your luck with PCM4Less.
I have a 305 cam also. With a full bultons, M6, and every syspension upgrade possible. I was able to go mid 12s at 112mph. I currently swaped to a th350 and this weekend am look in to put it into the 11s. This cam really works well with stock heads in my opinion.
with the CC305 do you still retain a lot of low end torque i have an M6 with 3.42's in the rear and dont really want to go to 3.73's unless i have to, if i go with this cam i plan to do some LT's at the same time and already have slp intake and hooker catback are the gains from this cam pretty noticable?
Originally Posted by Fbody4Ever
MC Racing can and does tune LT1's.
