do you think this cam is to big for a stock LT1 short block?
Maybe it's work but you should be take the safe side for your engine, you need a good space between the valve and piston.
My friend car is Camaro LT1 mods: Daimond pistons, Eagle Rods, LT1 ported heads, custom cam from FMS 234/242 575"/595 112LSA
I'll be installing my new cam soon and it's 248 int./254 exh. 0.562 int./0.580 exh. lift, 110 and it's hydraulic cam. That's with 1.5 RR. Was told not to use 1.6 RR to avoid piston to valve clash. I will use my 1.52 comp cams magnum RR.
A friend has it on his 383 LT1 with TF heads and it's awasome cam but not a DD.
You should be fine with that cam but if that is with 1.6 RR, I would suggest 1.52 RR to be on the safe side. Check your piston to valve clearence specially the exhaust valve since it's very close with.0595 lift.
GM847 has 0.539 int./0.558 exh. lift with 1.5RR. 0.574"/0.595" is with 1.6 RR.
Funny thing is my cam is also a custon grind from FMS
Originally Posted by 2MuchNos93LT1
FMS copied the gm847 lol (fms specs FMS 234/242 575"/595 112LSA) (gm847 specs FMS 234/242 574"/595 112LSA)
At this time, i'm trying to change my cam with same my setup, i hope to find something more aggressive than old cam. checkout this custom grind from FMS 237/244 .575"/.595" 114 LSA. this cam is already install it.
thats all up to you... how much are you willing to give up on driveability?
but really i would figure out what your heads are going to flow to see what cam you car will want... just becuase its a big cam doesnt mean its going to be faster then a smaller cam.
oh and im running 600 lift and i checked my piston to valve clearence and its got plenty of room.
