Using LT1 Edit, how do you turn off the knock sensor?
Old Nov 1, 2005 | 05:14 PM
matt94z's Avatar
Default Using LT1 Edit, how do you turn off the knock sensor?
I'm picking up false knock, and I wanna turn or tune the knock sensor out. Thanks in advance.
Old Nov 1, 2005 | 09:35 PM
dhdenney's Avatar
In addition to unplugging it, I went through all the retard tables and just set all parameters to 0. Run the communicator to verify there's no knock. I ran it to double check myself and I missed a table or two.
Old Nov 1, 2005 | 09:42 PM
TwoFast4Lv's Avatar
set the values at idle to 0 degree's you can do it for all the tables and you will never have knock retard...in some cases of young tuners the pistons follow
Old Nov 2, 2005 | 07:43 PM
matt94z's Avatar
whats the max timing I should leave my car at? The pcm was tuned by Pcmforless.`
Old Nov 2, 2005 | 07:47 PM
94 TA TT2S's Avatar
You have some weinners working on your car.....Don't ya......I understand take wht you can get...hehe
Old Nov 2, 2005 | 08:11 PM
matt94z's Avatar
should i be worried? Do you remember what Ed Wright set your timing at when you had yours turned off?
Old Nov 2, 2005 | 08:57 PM
TwoFast4Lv's Avatar
start with 32 in the 90-100Kpa tables 3000 and up this will give you 34-37 at WOT
Old Nov 2, 2005 | 09:26 PM
matt94z's Avatar
On my Auto Xray, it says I have up to 40* is this way off?
Old Nov 2, 2005 | 10:33 PM
TwoFast4Lv's Avatar
nope there are adder tables that add to what ever is in the table I told you about
Old Nov 3, 2005 | 10:38 AM
dhdenney's Avatar
I think 37 or so is about what I get with no knock sensor. Maybe a little higher at times.
Old Nov 5, 2005 | 07:54 AM
matt94z's Avatar
Well, I decided against turning the knock sensor off, and finally got the old sensor out. I had to warm up the car, soak the sensor with pb blaster, and use a cheater pipe to get the thing loose. Anyway thanks for all the help, as I will be needing tuning advise in the near future since my new tunercat program will be here this week. Headed to the track this morning, so wish me a new best.
Old Nov 5, 2005 | 11:37 AM
TwoFast4Lv's Avatar
Damn that is pretty tight for a sensor that is only supposed to be 14ft Lbs tight!
Old Nov 6, 2005 | 09:02 PM
BadAssFast's Avatar
Originally Posted by matt94z
whats the max timing I should leave my car at? The pcm was runed by Pcmforless.`
pcmforless did what "runed" ?
Old Nov 6, 2005 | 10:39 PM
matt94z's Avatar
Tuned, sorry it was a typo. Pcmforless does an awesome job on mailorder tuning.
Old Nov 7, 2005 | 07:38 AM
BadAssFast's Avatar
Good i was afraid you meant ruined ... I have heard excellent things about these guys.
Old Nov 8, 2005 | 06:57 PM
litscot's Avatar
he said ...............rooned!!!!
Old Nov 8, 2005 | 07:23 PM
BadAssFast's Avatar
**** howdy...you must be in southern iraq bubba!!
