Manifold gaskets???
Old Nov 4, 2005 | 09:04 PM
alconk's Avatar
Default Manifold gaskets???
I'm installing P.S. LT headers and wanted to buy a better set of gaskets to use instead of the paper ones that comes with it but the problem is every set I buy will not work. At both ends the bolt holes are moved about 1/2" outboard to use on the outer holes on the head but the Pace Setter uses the inner holes so what do I do???
Old Nov 4, 2005 | 09:13 PM
SmokedOutZ28's Avatar
check out or sponser Speed INC www.LS1speed.com i got my gaskets for $20 and new ARP bolts for $23 the bolts don't back out anymore and the gaskets dont leak.
Old Nov 4, 2005 | 09:21 PM
alconk's Avatar
Well I see that Mr. Gasket has copper ones for the LT1 I just don't know about the bolt holes?? I have a set coming for Sun. so well see???
Old Nov 4, 2005 | 09:48 PM
well to help heres the MR gasket part number that was on my invoice when i got them for my car MRG5903
Old Nov 4, 2005 | 11:47 PM
alconk's Avatar
was that using headers??
Old Nov 4, 2005 | 11:49 PM
alconk's Avatar
Part # I had was #7154???
Old Nov 5, 2005 | 05:09 PM
ExtinctBird's Avatar
I used FelPro 1470 gaskets with my PS headers. I have not had any issues with them. These are described as LT1 header gaskets. I know that alot of folks use a different FelPro gasket number too, 1406 (I think). These have loops for the last bolt holes, which allow you to start these outer bolts first on the headers then drop the gaskets into place. I didn't have any problems aligning through all of the bolt holes.
I used ARP 3/4" HEX stainless bolts, and am very happy with them as well.
Old Nov 5, 2005 | 05:24 PM
yes that was using PS headers, Hmmmm maybe theres a couple different one's that can be used with PS headers.
