LT1 performance
Old Nov 7, 2005 | 06:19 PM
93FireRedT/A's Avatar
Arrow LT1 performance
hey looking for a converter, cam, headers, what are some good things to look at want to make around 350 RWH. Looking to beat up on a Mach1 so if you can think of anygood other eengine modifications please let me know
Old Nov 7, 2005 | 06:39 PM
97blkz's Avatar
Decent set of heads, cc306 cam, tires, long tubes and a vig 3400 stall and boom deep 12's dpending on where you live. Add a safe 100 shot of N20 and mid 11's!
Old Nov 7, 2005 | 09:48 PM
State69champ's Avatar
headers, cam and RRs you will be real close to 350HP
Old Nov 8, 2005 | 08:01 AM
Chris 96 WS6's Avatar
Don't do the cc306...there are much better grinds out there. Longtubes, LE2 heads and the xe 224/230 will make over 360hp to the wheels in an automatic car.........362rwhp to be exact in my car with a Vig 2800. Ran 12.26 at full weight on ET streets with 3.23s.
Add some 3.73s and more stall speed and you'll run 11s with a totally streetable package. The 306 would make more peak power but at the expense of low end tq (due to the overlap) and poor driveability as compared to the XE grind.
Old Nov 8, 2005 | 11:30 AM
Jordan57's Avatar
if you're only shooting for 350hp heads aren't a necessity. Shoot there are guys making 350 rwhp cam only on here. But if you want to step up and make some great power, a heads cam package is where its at. AI, LE, and eric bradby, Joe O setups are very reputable. An aggressive setup, with a good tune and all supporting mods will net you right around 400rwhp. A converter with a 3K+ stall range is required. Just get a good one for good driveability. Also, driveability is personal preference. When we did the cc306 in my buddies car with a 3200 converter it drove just fine for my tastes, with no tune at all. If it had a dyno tune I'm sure it would be more civil. Just know what compromises you're willing to make. Then get it done!
Old Nov 8, 2005 | 12:12 PM
BizZzatch350's Avatar
Moderator
The cars making 350 cam only are also six speeds with 10 bolts, a stalled auto will have a helluva ahrd time making that kind of power to the back tires.
Old Nov 8, 2005 | 04:09 PM
Jordan57's Avatar
In most instances...but a lot of people's setups are a little out of sync. For instance, I would bet an a4 with a decent converter (3kish) with a gm847, gtp6 or similiar, with rr's, lt's, ory, good tune, and a 12 bolt would top 350rwhp.
Old Nov 8, 2005 | 09:07 PM
what do you guys think of this Total Engine Airflow custom ported heads, 3800 stall converter, hooker headers (long tubes), the GTP6 cam, port matched LT4 intake, and a 4.10 gear. What do you guys thik i will run. Got a good set of drag tires already. if you guys can think of anything else that is good please let me know
