miss.. new headers
Old Nov 13, 2005 | 11:56 PM
BLACKTA350's Avatar
Exclamation miss.. new headers
I have a 1997 T/A and i recently had put headers on it P.S...anyways it seem slike when the car starts to get warmed up it has a miss.. like when i put the car in park an go to the back of it i can here it poppin/missin... can this be wire or spark plug..i had one spark plug that i chipped by accident puttin th header sin but i replaced that spark plug any ideas
thanks, james
Old Nov 14, 2005 | 06:39 AM
Klortho's Avatar
Could actually be an O2 sensor that is heading south since you mentioned it didn't do it until it starts to warm up, that's usually when it starts going into closed loop mode.
Old Nov 14, 2005 | 08:29 AM
brandboZ28's Avatar
Check all of your wires. Its a pretty regualr occurance to burn a wire after a header install.
Old Nov 14, 2005 | 08:38 AM
Mike96LT1's Avatar
Are your headers coated? Reason I ask is as stated above it could be the 02s from the coating burning off and fouling up the 02s.
Old Nov 14, 2005 | 08:39 PM
BLACKTA350's Avatar
nah there not coated.....any suggestions.. the right side oxygen sensor i replace already cuase it was to stuck on to get offf
Old Nov 14, 2005 | 09:37 PM
dhdenney's Avatar
Another vote for the O2s. Something could have easily happened to them when you were removing them for the headers.
Old Nov 14, 2005 | 09:59 PM
Steve0's Avatar
You say it starts stumbling when its warm? Electrical resistance goes up with heat.
I'd bet its a either a burnt wire, or your coil. I'd check each wire, even consider switching to an over the valve cover set up to help keep from burning wires in the future. If that doesnt help, check the coil.
Old Nov 14, 2005 | 11:07 PM
Formula WS6's Avatar
I vote burnt wires.
Old Nov 15, 2005 | 12:27 AM
BLACKTA350's Avatar
alright thanks guys!!
