2nd gear start question.
Old Nov 15, 2005 | 05:53 PM
Dragframe's Avatar
Default 2nd gear start question.
well im probly going to buy a 96 TA tomarro. It is real clean on the body.
It has 81,000 miles on it.
It has a brand new motor with like 50 miles on it. The motor has a 5 year 100,000 mile warrenty on it.
Automatic
It has every option but the ws6 package.
The porblem is that the 2nd gear start button doesn't do anything. What could be wrong? It doesn't light up or anything. Could it be a fuse? A ground? Maybe a faulty switch? Something else?
and most importantly... if the second gear start button doesn't work, will it affect anything else?
I really need to know about that 2nd gear start thing by tonight... thanks a ton guys,
Nick
Old Nov 15, 2005 | 06:14 PM
TwoFast4Lv's Avatar
that is actually a "performance" switch. should just raise normal shift points and firmness nothing more
Old Nov 15, 2005 | 06:29 PM
Dragframe's Avatar
come on man.. seriously tell me what is up
i mean.. it is still starting in first gear... i can feel it. You can tell by when it is shifting...
so what could be wrong with the switch?
Old Nov 15, 2005 | 07:15 PM
Dragframe's Avatar
come on gyus... are you kdding me? no one can give me a simple anwser?
THis may be the difference in my buying this car or not
Old Nov 15, 2005 | 07:23 PM
infinitebird's Avatar
I'm not sure what you are referring to by "second gear start button." If you mean the performance mode button, the car never starts in that mode, you always have to select it after you turn it on. If you mean something else, what specifically?
Old Nov 15, 2005 | 07:30 PM
Dragframe's Avatar
THere is a button... behind the gear selecter/shifter... it says "2nd gear start" under it. And it doesn't do anything. we had the car running (duh... lol)...
Old Nov 15, 2005 | 08:43 PM
rbobryk20's Avatar
big deal if it doesn't work its second gear start.
Old Nov 15, 2005 | 08:51 PM
Dragframe's Avatar
lol.. so im taking it 94 and 95 had a performance button there?
And i have a second gear start button there? Anyone have this button?
Old Nov 15, 2005 | 09:11 PM
TAEnvy's Avatar
I dont know much about autos, I'm more of an M6 man myself, but it would seem like it would be used for bad weather. Other than that I dont know why it would be there. I've never heard of this before.
Old Nov 15, 2005 | 09:20 PM
buffman's Avatar
Neither have i..
Old Nov 15, 2005 | 09:21 PM
Dragframe's Avatar
well yeah...
iveseen it on other cars before
but what im wondering is if it is all computer controled. Like is there anyhting different about the tranny than any other auto tranny in a TA? So if it is broke, it doesn't affect the tranny in any way.?.?.?
In that case the only things that could be wrong is a fuse.. faulty switch... or ground or something.
But if it has something in the trans.. like physicaly.. would it being broke cause a problem. That is what im asking.
Computer or physical???
No problem or problem if its not working?
Old Nov 15, 2005 | 09:24 PM
Chopstix's Avatar
The thought the second gear start was an option on the V6's
Check the VIN on the car you are looking at.
A V8 model should be 2G2FV22
If the button doesn't work it is not a big deal.
Old Nov 15, 2005 | 09:28 PM
Dragframe's Avatar
well... it is a Trans Am... not a firebird... or a Firebird Formula... a TRANS AM.
All trans ams have v8s. firebirds have v6s... then the formulas have v8s... and yeah... you know...
So im possitive it is a v8 car. I know the original owner... it is a v8 car.. lol
Old Nov 15, 2005 | 10:20 PM
SmokedOutZ28's Avatar
To help take a pic of this button in question and post it..
***EDIT****
I wouldn't go jumping down chopstix throat about it being a TRANS AM because that is a v6 option and is not heard of on the LT1's.... alot of guys seem to have the same thought after i searched other sites and the net.
That button is used in conjunction with the computer on the v6's to keep the tranny in 2nd gear while taking off to limit rear tire spin.. you don't have a special trans since all the shifting is done electronically. This option is not used on the v8 since there is a tc motor under the hood that is used to limit throttle input under hard accel. What you may have is a swapped shifter plate or maybe a v6 thats now a v8 with new badges. best bet is to check vin and rpo codes look for P in the 8th letter vin and a rpo code in the glove box that reads LT1. If not leave it be.
Old Nov 15, 2005 | 11:03 PM
Dragframe's Avatar
***EDIT****
well my buddy knows the original buyer of the car.. so i know it is a trans am. But i will check the vin either way.
and bout this... "tc motor under the hood that is used to limit throttle input under hard accel." if i do have this... how do i eliminate it (that is if it does have it considering it has got this mistery button)? lol... got a car to roast em... and i know she can do it.
Old Nov 15, 2005 | 11:06 PM
97MysticZ's Avatar
What's a Sticky?
I'm with SmokedOutZ28...
It is also more believable since the motor was just replaced. Just because it says Trans Am on the side doesn't mean its a Trans Am...
Old Nov 15, 2005 | 11:08 PM
97MysticZ's Avatar
What's a Sticky?
Not all of the cars had Traction Control, and yes it can turned off.
Old Nov 15, 2005 | 11:44 PM
silver30th's Avatar
i have this SGS button too...mine doesnt light up either...WTF
Old Nov 15, 2005 | 11:58 PM
There should be a on and off switch.... if you do have it, it will be under the hood on the driverside sitting in conjunction with the throttle cables.
Don't worry nothing is soposed to light up!
