stock lt1 1/4 mile times
#61
Originally Posted by Shon Herron
that is how I felt about my 94PPM car, more and more time/money and didnt pick up anything.
And you are right, no matter what you run, I will still have the M6 record, HA!!
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#63
Originally Posted by 95formulalt1
hows the sound?
i got a flowmaster muffler and it sounds real nice. deep and throaty not raspy. i get a little crackling sometimes when i floor it and let off the throttle real fast but that hasnt happened in a while.
#66
Originally Posted by fastlt1
What is the Russ mod?
We leave at the same RPM and have the same 60's, he just can hit the shifts alot better than I can.
#70
is it loud or jst right?
its just right not loud at idle or cruising just a a low deep rumble nothing obvious and then when you hit the gas it really comes alive. personally i would have liked to have it a little meaner sounding at idle. when u first turn the car on the idle sounds just the way id like it to but once the car warms up it quiets down a bit.
i guess ill have exactly what i want after i get a new cam and the heads done.
#73
i had a 95 z28 stock lt1 6 speed with no cats, ebay intake, and a set of mickey thompson slicks on the stock wheels, with a cheap flow master exhaust with stock piping, and my best run in 90 degree was a 13.601 at 104 mph powershifting it.
#75
WOW, brought back from the dead...
Mine went 13.50@103.9 on a 2.0 short time the only time at the track it was bone stock in 96. Put 4.10 gears, K&N, 160 t-stat, and HPP+ for the speedo and went 13.18@104.9 on a 1.89 short time. Both times were at MIR and still on the original GSC's. Think I had 6K miles on it by then.
#76
My brother bought his 97 m6 ss new in 97. hundreds of BONE STOCK (actual stock not the loser drag racer definition) runs filed away. paper filter, comp ta zrs lvl 2 suspension and totl exhaust the whole factory bit.
Best are 14.00 @ 99.9 mph (best e.t and mph listed) almost all close runs are 14.0-14.1 @ 99-99.9 mph. best 60' was 2.1 ish so with a 1.8 or 1.9 id say 13.8s were about the best he'd go but thats speculation. About 40 runs in englishtown NJ, maybe 250 runs at Toronto motorsports park, 50 or so at St.Thomas and a few hundred on toronto streets after 3am
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#78
Bringing back some memories. Check this out. My '95 A4 ran 14.6-14.7 bone stock. With no power adders (only boltons) I ran high 11's. How 'bout a trophy for most improved without a power adder. LOL!!!
I was disappointed the night I broke the record because the weather was perfect and right before the sun went down the xmas tree broke. With the cooler temps I would have picked up another 2-3 tenths which I really wanted to see. Unfortunately it didn't happen, at least not officially. :/
