oil cooler removal
oil cooler removal
im not sure if i should remove it or not on my 95 z/28 ive got a heads and cam pacage on it awhile back i got it hot and it spun a bearing when i removed the cooler all the little fins were plugged with material and i dont know if that cause my bearing spinning or it was a result either way i think its a **** poor setup wondering if anybody has taken thiers off or seen a increase or decrease in oil pressure also i know all 94's came with a cooler being mine is a 95 how do i tell if i have the 1le package or the car was just ordered with a cooler
Originally Posted by smoknta
I've got a 93 TA can I just remove the cooler and the filter mount right up? Do you think it keeps the oil cooler with or without it?
