Next bolt on?
Old Dec 3, 2005 | 05:48 AM
matt94z's Avatar
Originally Posted by Slw94LT1
i been 1.63 on stock suspension with a 2800 stall and 3.73's and DR's
I need to see a list of mods, and race weight of your car or I'm calling do you have any vids or timeslips to post???
Old Dec 3, 2005 | 09:27 AM
BigKap94z's Avatar
Originally Posted by StealthFormula
Flowmasters were only proven to loose hp on applications where cam and heads were used and like 5 hp at the most. A stockish car will not loose any hp from a flowmaster exhaust. I dont think the cutout would help much in hp at all. Anywayz if you can, get a converter definetly, thats next on my list as well.
Thats not accurate. Go over to CamaroZ28.com and do a search. There was a number of people that did dyno testing that showed on cars with bolt ons, and some with H/C the flowmaster was 20+HP LOWER @ the wheels. Its been a while since I have researched this, because I have seen enough proof to make the case. There was another guy that was calling BS, then he had his car dyno'd back to back with the flowmaster, and then with the cutout open and picked up somewhere between 17-20 RWHP.
Old Dec 3, 2005 | 10:40 AM
brandboZ28's Avatar
You can get a Midwest or TCI converter new for about $450 but Im not sure about the price of the install. I did that myself. As others have said, its by far the best bang for the buck mod I did. Gained .7 of a sec in the 1/4 with it. There is one big problem with going with a stall converter though. Traction.
I went 1.63 a few times with my setup and the only suspension I have is BMR LCA's and relocation brackets with a Eibach ProKit on DR's. I could probably squeeze a little more out of it with a set of SFC's.
Old Dec 3, 2005 | 11:19 AM
Speed Density's Avatar
hashtagBMW
Im gona have to say............Converter. If you have a good mechanic, I could see it all being done for 1200 bucks.
Old Dec 3, 2005 | 01:40 PM
Camaro 0wner's Avatar
Where can I go to get some relocation brackets? Any mechanic? Also, where should I buy it?
Old Dec 3, 2005 | 03:06 PM
transamtom's Avatar
I say get the converter,if not then get a decent catback exhaust or a cutout.
You don't need the LCA relocation brackets until you have the car lowered,I would also suggest some aftermarket lower control arms if you do the brackets
