best head gaskets for lt1
Old Dec 2, 2005 | 12:59 AM
pugads650's Avatar
Default best head gaskets for lt1
whats the best head gasket i can buy for my lt1 camaro i just found out today they are blown also whats a good price on getting this fixed my mech already quoted me 1600.00 for the head gasket i think its kind of alot beacuase the gaskets are 100-120 bucks thank's.
john
Last edited by ACW; Jan 9, 2006 at 05:31 PM. Reason: restoring original post instead of "tttttt" garbage
Old Dec 2, 2005 | 07:29 AM
BigKap94z's Avatar
john
Is your engine stock? If so stock ones would work fine. I would use Mr. Gasket 5716's. They are a very good gasket, like $35 for the pair. These are thinner than stock and will boost the compression alittle as well.
Old Dec 2, 2005 | 09:42 AM
pugads650's Avatar
do you think 1600.00 is alot to change them or should i look for another mechanic thanks john.
Old Dec 2, 2005 | 09:56 AM
96capricemgr's Avatar
I would second the Mr. gasket recommendation but add you might check with the mechanic and ask if he is planning on having the heads resurfaced I would recommend this anytime a head gasket fails as it might be the reason for the failure was a slightly warped head.
$1600 is a lot BUT you are in CA and this is a BIG project we are recommending a cheaper gasket which will help, if his figures include having the heads sent to a machineshop then consider that in the price. I bet book on this is over 10 hours also check what extra parts and fluids he is including. You need a full picture of what is included before you can compare and then again consider labor will be VERY high where you are.
Old Dec 2, 2005 | 11:10 AM
97MysticZ's Avatar
What's a Sticky?
You could just save yourself a lot of money and do it yourself. Its really not that hard.
Old Dec 2, 2005 | 12:03 PM
Docspeed's Avatar
Old Dec 2, 2005 | 12:31 PM
BigKap94z's Avatar
I agree with what was stated here. If your not sure its the headgasket, do yourself a favor and get a second opinion on the problem.
Old Dec 2, 2005 | 12:48 PM
TurboZ28's Avatar
Even better is get a gasket from the iron head Impala SS LT1. I heard the they were thinner therefore increasing compression. Not sure of the validity of this claim but thats what I use on mine.
Old Dec 2, 2005 | 01:07 PM
BigKap94z's Avatar
Thats another good option. They are .029" thickness compressed, and more expensive than the Mr.Gaskets which are .026" compressed.
Old Dec 2, 2005 | 08:23 PM
Ed Wright's Avatar
9-Second Club
What is the compressed thickness of the Mr gaskets? The Impala gasket is .029" compressed. FelPro is thinner than the factory F & Y body gasket, but thicker than the Impala. (.036" or .038" I think) If you have .005" or more deck clearance (factory stock LT1s all do) I would use the Impala gasket.
Good luck, Ed
Old Dec 3, 2005 | 09:30 AM
BigKap94z's Avatar
Good luck, Ed
The Mr.Gaskets are .026" compressed.
Old Dec 3, 2005 | 09:40 AM
Ed Wright's Avatar
9-Second Club
Good to know. Need to be at least .006" down for those.
Thanks for the info, Ed
Old Dec 4, 2005 | 05:20 AM
sssalah's Avatar
Both of these gaskets (impala & Mr. Gasket) are made for iron headed motors. There must be a reason why manufacturers are making different ones for aluminium heads. Yeah, it might be the different expansion rates between the 2 metals and the allawance of this movement over the gasket surface or could be something related with corrosion.
Old Dec 4, 2005 | 09:27 AM
Ed Wright's Avatar
9-Second Club
The Impala gaskets (and I'm sure Mr. Gasket also) work fine with aluminium heads. Many people have used them for many years. I've used the Impala gaskets on mine for quite a while. It's a pretty common practice.
Ed
Old Dec 5, 2005 | 01:49 AM
sssalah's Avatar
Ed
Yes, it would be easier and better to control the quench distance by using a thinner head gasket instead of decking the block.
