super gasy smell
Old Dec 3, 2005 | 08:55 PM
skatinjay27's Avatar
Default super gasy smell
I need to get emissions in a week and car smells very strong of gas and woried it wont pass please help.whaT DO YOU THINK THE PROBLEM IS
Old Dec 3, 2005 | 08:59 PM
zlover129's Avatar
maybe the Cat, or even a leaking line, have you looked under the car after it idles a while?
Old Dec 3, 2005 | 09:09 PM
for leaking gas?
Old Dec 3, 2005 | 09:16 PM
zlover129's Avatar
Originally Posted by skatinjay27
for leaking gas?
no, either its the cat OR your leaking gas
Old Dec 3, 2005 | 09:30 PM
95zpro's Avatar
check your o2's as well;problem with them can cause you to be running rich......
Old Dec 3, 2005 | 10:05 PM
if my o2s where bad whouldent it throw a code
Old Dec 3, 2005 | 11:38 PM
Speed Density's Avatar
hashtagBMW
Not nescacarily, mine doesnt throw codes and i have shitty o2s. You might wana see if maybe your injectors are leakin and dripin on the manifold or heads. Or check under the car and see if maybe your exhaust pipes are touching fuel line.
Old Dec 4, 2005 | 09:56 AM
BDsSlowbird's Avatar
Is the smell coming from the exhaust or elsewhere? A bad EVAP cannister or fuel cap will cause a stink near the LH rear wheel. If it is coming from under the hood it could be a bad EVAP purge valve/solenoid.
Old Dec 4, 2005 | 01:43 PM
the hood and exhaust when go near the exhaust tips even for 5 sec youll get dizzy.
Old Dec 4, 2005 | 09:31 PM
97LT1's Avatar
Misadjusted rocker arms can make it smell gassy as well. But you should also be able to hear these.
Old Dec 5, 2005 | 02:18 PM
We are all just making educated guesses here, but I don't think a bad EVAP system would make you dizzy from the smell. Leaky injectors would dump a lot of extra fuel into the mix but I don't know if that would smell under the hood while the car is running.
