corvette valve covers
Old Dec 7, 2005 | 03:13 PM
jessebuickguy's Avatar
Default corvette valve covers
I have a 95z and I want to know if I can put on the black composite corvette valve covers on my LT1. Will anything get in the way. Thanks for the help
Old Dec 7, 2005 | 09:49 PM
transam5.7lt1's Avatar
I would like to learn more about it also......
Old Dec 7, 2005 | 10:16 PM
METALBEAST's Avatar
The passenger side valve cover may be a problem. The alternator for the F-bodies is mounted on the passenger side and the valve cover has a depression to clear the alternator. The alternator on the Vettes is mounted on the driver's side and as I recall, the valve cover did not have any depression to clear the alternator.
Old Dec 7, 2005 | 10:51 PM
Ed Wright's Avatar
9-Second Club
I had them on mine for about four years. Everything cleared just fine.
Ed
Old Dec 8, 2005 | 05:55 AM
sssalah's Avatar
Have them on my car too, they clear the alternator fine. Get the Corvette PCV vent tube with them as the opening is on the side rather than on the top.
Old Dec 8, 2005 | 11:10 AM
TwoFast4Lv's Avatar
They fit fine. Might have to clearance the inside to higher lift cams
I have the installed the black and early mag. covers with no issues
Old Dec 8, 2005 | 06:20 PM
Docspeed's Avatar
He's right. I just pulled them off this past weekend on my vette, no depression.
Old Dec 10, 2005 | 09:11 AM
Ed Wright's Avatar
9-Second Club
They cleared mine just fine, big bulky 1.7-1 Comp Cams steel rockers and all. Kinda liked it better when it still looked bone stock. Traded a '93 LT1 chip to a young man that worked at Pro Pan for a set of their killer fabricated center bolt valve covers, so I could install the girdle. Never had any issues at all with the Vette covers until the girdle.
Old Dec 10, 2005 | 10:03 AM
METALBEAST's Avatar
I had to trim the drip tabs of to get mine to clearance the Comp Cams Pro Mag 1.6/1 rockers. I could not get the valve cover to fit other wise. This was on my 1992 Vette.
Old Dec 10, 2005 | 10:33 AM
flatlander757's Avatar
http://www.afterthoughtsauto.com/lt1-frc.html
Old Dec 10, 2005 | 03:57 PM
Ed Wright's Avatar
9-Second Club
I have LT4 heads, if that makes any difference. I would not expect any. I used them on mine until the middle of this past summer. Never had to trim anything to ge them to work.
Old Dec 10, 2005 | 04:37 PM
METALBEAST's Avatar
Thats awesome! It was a real PITA to cut those drip tabs off.
