Cam Help
Old Dec 7, 2005 | 07:17 PM
buttermantoast's Avatar
Default Cam Help
I was wondering i have a 97 ta with minor bolt-ons. I was wondering what is the biggest cam i can put in it and which is the best brand.I read that when u go to a much bigger cam u need computer tuning i am wondering what would be the best gain in performance and of course sound love the way a cammed engine sounds without losing drivability cause its my daily driver!!!!
Old Dec 8, 2005 | 06:00 AM
sssalah's Avatar
Tuning is needed with any cam change IMHO, tuning could be usefull even with a stock cam. A bigger than stock cam may also require a stall change. The GM 846, hotcam and CC305 are all good all around cams.
Old Dec 8, 2005 | 07:49 AM
Not tryin to sound like a nub but what exactly is meant by tuning and can i run a cam without it. Also which kind of shops do this or can i do this myself??
Old Dec 8, 2005 | 08:07 AM
95zpro's Avatar
tuning=adjusting your timing, air/fuel ratios, and other engine calibrations thru the use of software such as LT1edit or some other type of software that will allow you to 'talk' to your cars computer. If you are new to this I would pay to have it done by a reliable shop or you can run the risk of really screwing your car up! And yes you will probably have to have your computer tuned if you do any type of power adder if you want to get the most gain/performance out of it.
Old Dec 8, 2005 | 10:00 AM
METALBEAST's Avatar
If your car is a daily driver, and automatic and you are not looking for huge amounts of power, you probably want to stick with a smaller cam. Some notable cams are in order of size the CC304,LT4 Hot Cam (not my favorite) and the CC305. Of the three cams, the Hot Cam is going to be the lopeiest cam since it has the tightest LSA.
Old Dec 8, 2005 | 12:58 PM
harvickgm's Avatar
or you can go all out, like im working on and go with a 108LSA and run like a scalded dawg.... and it sounds alot meaner, but alot more mods and tuning required as well.
Old Dec 9, 2005 | 03:23 PM
thnx that helps alot really appreciate it!!!
Old Dec 10, 2005 | 12:10 PM
One more question whats a good repitable website where i can view the specs on these cams and possibly buy one?
Old Dec 10, 2005 | 12:15 PM
METALBEAST's Avatar
Here you go
www.compcams.com
Old Dec 10, 2005 | 01:30 PM
brynnda's Avatar
www.cammotion.com is a great site for cam recommendations
Old Dec 10, 2005 | 02:13 PM
slowmofo's Avatar
http://www.cranecams.com/index.php?s...=305-350%20C.I.
cranecams
