lt4???
Good luck, Ed
Good luck, Ed
ok so all i have to do to not have to reflash the computer right away is run my injectors? and the guy said that bcuz it has a different throttle body that it needs redone for that? i have never heard of having to do that but i could be wrong.
Use your original throttle body, knock sensor and injectors, and you can drive it with no tuning. There is a little more power there with tuning. The Lt4 knock module lessens sensitibity to knock, but since it is desinged for a 1996 PCM and sensor, it is not the proper way to go. Just a band aid to cut back on knock retard. That sort of thing is best done in the tuning, using the correct knock sensor and knock module for the OBD1 PCM.
Good luck, Ed
www.cammotion.com is a great site to get a cam recommendation and they ship in just a couple days.
