cc305?????
Old Dec 11, 2005 | 09:12 PM
steez's Avatar
Default cc305?????
anyone run this camshaft? if so what rr's did you use and did you stick wiht the recomended 1:6 ( i hear 1:7's ona bolt on cam car is not worth it) also is there anyuthing else i will be needing? thanks in advance guys and what rr's woudl you advise to use thanks
Old Dec 11, 2005 | 10:33 PM
MEAN LT1's Avatar
1.6rr would be a good thing to go with with this cam. It'll give about .550 lift with the 1.6's. Wont sound as agood as the hot cam is slightly smaller but it should put down a little better numbers.
97Formy's Avatar
I didn't think they made 1.7's for LT1's (could be wrong though). From what I've read so far on the subject the cc305 is pretty much the same as the LT4 hot cam. So I would have to recomend the Hot cam kit for you(from what I understand it's the cheaper route). It comes with pretty much everything you need. RR's, springs, caps, keys, and shims.
Old Dec 11, 2005 | 10:40 PM
MEAN LT1's Avatar
the 305 is bigger.
Old Dec 11, 2005 | 10:48 PM
97Formy's Avatar
Originally Posted by MEAN LT1
the 305 is bigger.
I was just saying they were similar. Hot cam 218/228, 525/525. CC305 220/230, 510/510
Old Dec 11, 2005 | 10:58 PM
RoAdRaGe912's Avatar
for your specs there you're using 1.6 RRs for the hotcam and 1.5 RRs for the cc305.
it's a decent cam, and can be hidden completely with a good tune. 1.7s on stock heads really aren't worth it. you'll get slightly better duration at good flow lifts but you're lifting a long way for nothing. i'd stick to some 1.6s (which will get u .544 lift instead of .510).
just because they are similar doens't mean that the same stuff that works for the hotcam will work for it. the LT4 springs are barely adequate for the hotcam itself. they are only rated to .525 lift.
Old Dec 11, 2005 | 11:27 PM
97Formy's Avatar
Cool, thanks for the info, I didn't know that I don't really know much about these cars but I'm learning Just thought I'd help out were I could(or thought I could anyway). Sorry
Old Dec 12, 2005 | 12:47 AM
it's cool, i was just correcting. we all have to learn it at some point.
Old Dec 12, 2005 | 01:39 AM
steez's Avatar
ah you guys are the best...so you figure the cc 305 is the better route?
Old Dec 12, 2005 | 02:21 AM
DarkDemon's Avatar
i have a 305 and i'm going 306
Old Dec 12, 2005 | 03:28 AM
skatinjay27's Avatar
not neccesarly the 305 only makes more power at very high rpms .ya it gives a lil more power but hotcam is much more cost effective . and please no one chime in and start BASHING the hotcam
