Head Choices?
http://www.trickflow.com/product/che...t1_airflow.asp
Formula_Lt1,
Do you know what your stockers flow or how good they are?
Bret
Hmm.. The engine in question, a 396, is making 412WHP with crappy headers, moderate cam of unknown specs and ported stock iron (!) heads. I don't think the TFS parts would do much more than lighten the front end with those flow numbers...
Bill it's B R E to the T.... I know you and my father are real close in years, but if I recal the orginal Bret Maverick (James Gardner) spelled it the right way too ;-)
Bret
Bret[/QUOTE]
I had a guy do them locally and he put them on a flow bench, but I don't remember what the #'s were. For the price, the port job was well worth it. I'm out of Ashland, ky and the guy has his own business (PTI) and he used to work for Performance Eng. in down town Ashland. Does really good work.
As far as how good they are? They helped out quite a bit, compared to stockers. Accoring to tuner cats, the mass air was reading 330gps, with ported heads/hot cam/LT's/CAI/58mm TB/ and 30lbs injectors. My buddies car with similar mods (with sock heads) were around 300 odd sum GPS.
Bret
Bret
As far as how good they are? They helped out quite a bit, compared to stockers. Accoring to tuner cats, the mass air was reading 330gps, with ported heads/hot cam/LT's/CAI/58mm TB/ and 30lbs injectors. My buddies car with similar mods (with sock heads) were around 300 odd sum GPS.[/QUOTE]
I am topping 320gps with the Caprice in my sig, cam smaller than 99% of f-body guys would even consider and stock iron heads, this is maxing out the stock injectors still in the car, O2s look good to that point at which point it goes lean, which confirms these are good readings and not a funky sensor overreading. If the sensor was overreporting it would be rich.
....check out parting out highly modified 94z....my heads/cam are similar to the LE3 and both for $1400...
