LT1 Cubes?
Old Jan 3, 2006 | 08:24 AM
01SSDRVR's Avatar
Default LT1 Cubes?
I was curious as to how many cubes you can go with a stock LT1. I know you can do a 383 but is that the biggest? Thanks for any info
Old Jan 3, 2006 | 08:43 AM
Chris 96 WS6's Avatar
396 is common...you can go bigger but as with everything else it costs more.
Lingenfelter once built a 454ci Small Block. Since the LT1's rotating assembly is the same, I assume with enough cash to throw at it you could make an LT1 that big.
Old Jan 3, 2006 | 09:51 AM
MattZ28's Avatar
Lingenfelter built a twin turbo 427 LT1. That's the biggest I know of.
Old Jan 3, 2006 | 11:08 AM
01SSDRVR's Avatar
How big can you bore the stock sleves? how big of a stroke can you go without having to modify the block?
Old Jan 3, 2006 | 11:23 AM
buffman's Avatar
The largest cube LT1 that I know of that's doable is like 409-411 cubic inches. Of course then there's Jeff Green who converts donovan 400sbc aluminum blocks to LT1s and I think you can go up to the 450 cube range with those.
Matt
Old Jan 3, 2006 | 12:03 PM
BizZzatch350's Avatar
Moderator
The thing is its pointless to go super huge most people cant even optimize a 383 in their street cars much less a 396, more to building a well working car then just throwing the biggest bottom end you can find.
Old Jan 3, 2006 | 02:33 PM
01SSDRVR's Avatar
The car will ba able to handle it. Its a 68 camaro that's getting minitubbed and a 4 link. I wanted to know if you could do a 406 or something bigger with the stock block.
Old Jan 3, 2006 | 03:08 PM
LT1 = IRON block...no sleeves...its all one piece.
You can bore .060 over safely, which will take a stock stroke LT1 from 350 to 358.
Old Jan 3, 2006 | 03:55 PM
01SSDRVR's Avatar
Thank you
