pistions at 30 pounds
Old Jan 8, 2006 | 06:39 PM
1bottled93toenvy's Avatar
Default pistions at 30 pounds
ok well i have been having problems with my carfor a while so itgot to a point where i took it to a shop...the end result was they told me i dotn have any compression in cylinder one...its not even firing, cylinder 3 is at 30 pounds and cylinder 5 is at 60 pounds...he also says it looks like theres more internal engine problems and i need a new motor...now i dont know what to do...i was fixing my car to sell it and now i dont know if its worth it to drop more money into the car to just sell it or to part it ou and count my losses...i dont know about he compression.. was thinkg it could be a head gasket too a???...im not really sure..any help on this one would be good..thanks in advance
Old Jan 8, 2006 | 07:04 PM
hondo's Avatar
Leakdown test would shed some light on what the prob really is. Does it smoke or any other symptoms?
Old Jan 10, 2006 | 08:17 PM
well the car wont even start at the pressure pounds....itt goes up and down from cylinder 3 it will be 140 pounds then go down to 30 pounds back to 100 then to 60....i dont really know what to do...i was thinkg head gasket but i dont think so...any more help?...i relaly need some
Old Jan 11, 2006 | 01:40 PM
ttt.......aynoe
Old Jan 11, 2006 | 02:00 PM
Fire67's Avatar
When doing a compression test, you should have a gauge that will hold the highest pressure reading. When you turn the motor over, it will slowly build up higher with each stroke. When it stops climbing, thats your reading.
All cylinders should be within 10% of each other for a stock motor.
If you had a head gasket blow, you will most likely see coolant in your oil. Sometimes the gasket can fail between two cylinders though, and that wouldnt show any coolant in the oil.
When my motor went, it wouldnt build over 30psi in cylinder #1 no matter what. My #5 was fine, but #7 was at 70psi. The rest of my cylinders were all between 145psi and 155psi.
If your not sure about the results of your compression test, do a leakdown test, it will definitely let you know whats going on.
Old Jan 11, 2006 | 02:32 PM
roughneck427's Avatar
Well you need atleast 100 psi to fire it sounds maybe you have a blown headgasket between 3&5 do the leakdown test like the other guys said
Old Jan 11, 2006 | 03:42 PM
Ari G's Avatar
coulden't this be a case of pre-ignition if the pressure build up,goes down and then hits the max on the same stroke or detonation??Air in the cooling system,to rich etc..
Old Jan 11, 2006 | 03:54 PM
Fire67's Avatar
uh, he's not igniting fuel to do a compression test.
It does sound like it could be a blown head gasket between the two cylinders though. That could explain why he gets erratic readings. Like I said, a leakdown test would confirm the culprit.
Pre-ignition from the juice could very well have caused a blown head gasket. Whenever you get it fixed, you should have your tune checked to make sure your not detonating when you spray.
Good luck!
