Custom Grind Cams For LT1?
I would spring for stock head porting, around $350, then look at something like the CC 07-503-8, 224/230. It is a more intense (faster ramping) cam than the 306. If you can spring for new springs and 1.6 roller rockers you would have a really solid setup.
The head porting alone should be worth 25HP/33TQ across most of the board. It will allow that cam to shine.
Remember, everything in your combo has to match your use and the car's real capabilities.
Jim
Mec
I Know two locals that went that big in M6 cars with 4.10s one ended up selling the car the other bought another so he could enjoy driving an f-body again. Neither ended up fast. Had they ported heads it might have worked better. This is THE classic gearhead mistake, the "more is better" syndrome.
If your car is a DD, and you are expecting some sort of longevity after you put the cam in, then I would go smaller. If you don't mind revving the **** out of your 138K mile bottom end knowing that it will most likely be broken before to awful long, then go custom or 306 sized cam.
The CC-305 is another good choice. A good old school cut ,will last a long time with out taking out the valve train. They make good power(we have made over 400RWHP Un-locked) and are still pleasent to drive.
The CC-306 was very popular back in the day. Many never tuned them in good and gave up on them. Then tuning came along and they were ok
there are many better choices. If all you want is the sound? you can get it and much better drivability with a 21x/22x 112 cam
And? I ran a GM 847 and ran 11.85 N/A on stock short block and LE1 heads
Ran geat on the street but there was alot of tuning to get there
Never pulled the trigger on the Juice.Right now "I" am living with a 24x/24x 110 LSA cam in my street car
I would NOT recomend my cam for anyone else unless they had the same combo and desires I do.As is the norm with cam choice it is all about WHAT the owner is willing to live with. IF the desire is just to have a car with "That" sound I would not choose a CC-306
This is JUST my opinion nothing more
Remember, a car with great heads and an OK cam will always work better than a car with crappy heads and a great cam.
You can keep asking people until you get enough people that tell you otherwise, but you can't get away from this fundamental truth. At some point, you must get good heads. Your motor is simply an air pump, self powered. The intake, heads, cam, compression and exhaust need to work in concert before you get really fast.
The web is full of "experts" that tried to get around this, but failed. Don't be one of them.
Jim
Jim
I would agree that head and cam are the best way to make power. The combination is the key.
Bret
