Catted Y- Pipe
Old 01-14-2006, 06:29 PM
flame's Avatar
The cats are made locally by a friend of a friend very similar to the ones from Pypes. I used the Pacesetter Y-pipe and welded the cats in. The cars a 96 TA
Old 01-14-2006, 11:25 PM
ReD95LT1's Avatar
How's the performance gain and what other mods do you have
Old 01-15-2006, 11:31 AM
flame's Avatar
I did cam, headers, rockers all at once. Running the comp 306 with 1.6 promags.
Old 01-15-2006, 12:30 PM
ReD95LT1's Avatar
Does anybody have a link to a write up for the pacesetter headers on an lt1?
Old 01-15-2006, 01:34 PM
flame's Avatar
what would you like to know??
Old 01-15-2006, 02:46 PM
ReD95LT1's Avatar
basically everything start to finish lol.
Old 01-15-2006, 04:13 PM
flame's Avatar
I'll give you a few pointers : get good quality gaskets felpro's I used, locking header bolts are a good idea although I didn't use them, need O2 sensor wire extensions, use band clamps on the y to header connections not the crappy ones they give you, get the over the valve cover wireset or you'll be forever replacing burnt wires, need to remove steering shaft to get driver side in can't remember the passenger side. Hopefully that helps and I'm sure others can add in their experiences.
Old 01-15-2006, 04:30 PM
ReD95LT1's Avatar
Dont the o2 wire extensions come with the kit? Where do you get the over the valve cover wire set? Was it tuff removing the steering shaft?
Old 01-15-2006, 05:20 PM
StealthFormula's Avatar
Yea the 02 wire extensions come with the Pacesetters. You just gotta cut em and connect em and solder them I believe. Thunder Racing sells an OTV wire set. I didnt buy an OTV wire set and I prolly should have so hopefully with the coated headers I wont burn my wires. I have everything off of the car ready to put the new headers on except I cant disconnect the steering shaft. How do I DO IT????????????
Old 01-15-2006, 05:22 PM
flame's Avatar
They give you wire to splice them but unless you solder them properly it affects the signal. If you do lengthen do the harness not the sensor. thunder racing sells a kit which gives you wires, holders and crimping tool. The steering shaft comes off pretty easy.
Old 01-15-2006, 05:24 PM
flame's Avatar
Theres just a pinch bolt at both ends. Make sure you lock the steering wheel or you can wreck the airbag clockspring. pry the shaft off the rack end it will colapse then pull off the top end. The shaft is master splined so it'll only go back on one way.
Old 01-15-2006, 08:12 PM
  #32
ReD95LT1's Avatar
So your advice is to buy the thunder racing kit?
Old 01-15-2006, 08:15 PM
  #33
ReD95LT1's Avatar
I was on thunder racing, could you set me up with a link to what i would need from there, you talked about band clamps and it looks like they are on there too, just like to make the right decision, i would appreciate it thanks!
Old 01-15-2006, 08:23 PM
  #34
OVC wires last on this page
spark plugs, u want tr-55's
exhasut band clamps last on the page, 02 extensions are above it a little
Old 01-15-2006, 08:26 PM
  #35
I just finished my complete tear down of everything so now I can install my LT's, new plugs and wires etc. Took me 10 hours of work with my dad to get to this point so I suppose its a 20 hour job, wow!
Old 01-15-2006, 08:28 PM
  #36
ReD95LT1's Avatar
What all did you tear down? my headers should be here in a couple of days.
Old 01-15-2006, 08:31 PM
  #37
ReD95LT1's Avatar
what is the part number for the o2 extensions? And i think im gonna have to hold off on the ovc spark plug wires, too much money.
Old 01-15-2006, 08:38 PM
  #38
i followed the pacesetter directions.
took out headers, y-pipe, air and egr crap, starter, alternator, plugs, wires, intake elbow, MAF, cold air intake tube, battery, dipstick, steering u joint thing, gonna do thermostat thinger tomorrow, had to drain the coolant from the radiator and i drained the oil and took off the oil filter. I thinks that everything. Not too hard tho as long as u got all the tools and penetrating fluid. If u dont have an 02 sensor tool i recommend u get one i got mien at autozone for a couple bucks.
Old 01-15-2006, 08:42 PM
  #39
dunno which part number. Im just going to make my own with the supplied stuff in the from pacesetter. I didnt get tho OVC wires either because I didnt want to spend so much so I just bought taylor spiro pros for like $45 and hopefully i wont burn them up.
Old 01-15-2006, 08:56 PM
  #40
ReD95LT1's Avatar
But you did buy the band clamps?
Quick Reply: Catted Y- Pipe
