Catted Y- Pipe
Here are some pics:
Is there anything wrong with the clamps that pacesetter provides? Is this why you are getting band clamps?
Thanks for the pics, if you get more, post em
Oh, and Stealth, you're going to need to get your car a lot higher than that to get the headers in from underneath. And it looks like your jack is way to short to get it high enough so plan on getting another jack or something safe to put under the jack or on the jack plate for extra height.
BTW:Red95LT1 If you are going to run the ORY with and without cats you will need 4 bandclamps and 3 more if you decide to use bandclamps for the connection between the headers and y-pipe and y-pipe and catback. For plugs get NGK tr-55's.
And also what size o2 extensions do i need?
Could somebody put up a link on where to buy poly engine and tranny mounts for my 95 lt1?
A part number will help alot thanks!
I was looking at the o2 extensions and there are a couple there but for the lt1 they have one for the rear and one for the front, i will need both correct?
125-109009 Oxygen Sensor Extension, 42" Square 4-Pin (Rear Sensor on 1995-1997 dual cat LT1 F-body, Front & Rear on 1998-2002 LS1 F-Body) $25.00 Buy Wish
125-109007 Oxygen Sensor Extension, 24" Square 4-Pin (Rear Sensor on 1995-1997 dual cat LT1 F-body, Front & Rear on 1998-2002 LS1 F-Body) $25.00 Buy Wish
125-109006 Oxygen Sensor Extension, 12" Square 4-Pin (Rear Sensor on 1995-1997 dual cat LT1 F-body, Front & Rear on 1998-2002 LS1 F-Body) $25.00 Buy Wish
125-109011 Oxygen Sensor Extension, 24" Flat 4-Pin (Front Sensor on 1994-1997 F-body, Front & Rear on 1994-1996 Impala SS) $25.00 Buy Wish
125-109002 Oxygen Sensor Extension, 24" Single Wire (Front Sensor on 1993 LT1 F-body) $25.00 Buy Wish
125-104035 O2 Simulator (Single) - 1996-up V8 F-body/Corvette (2 required) - OFF ROAD USE ONLY $44.99 Buy Wish
Summit has the 4 wire flat extension part # CEI-109010 for $21.95
