real quick question....how much is stock fuel pressure?
Originally Posted by buffman
Mine is retarted. It's like 34-37 with key on and car started, and 42 with car started with vacuum off. I loose like 4lbs of pressure at WOT. Time for a new pump
u saying it's just not able to keep the pressure up at WOT?
Originally Posted by RoAdRaGe912
it should be the same at KOEO as it is at WOT and idle if you pull the vacuum line off the regulator.
Nope at WOT pressure starts to drop. with KOEO it gets no where near 42psi (where it usually is at idle with vacuum off) and at WOT it drops off about 4lbs. I thought at first maybe 12K miles was too much on the fuel filter, so I changed it out, and it was the same. I think the 155k mile fuel pump is getting old.
Matt
