Lt1 Timing Chain
Old Jan 24, 2006 | 06:35 AM
d-marlo1's Avatar
Default Lt1 Timing Chain
Does anyone make a roller timing chain for the early lt1?
Old Jan 24, 2006 | 08:39 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Lunati, its a single roller. GM sprocket but a Lunati Chain.
Old Jan 24, 2006 | 09:27 AM
d-marlo1's Avatar
The one I found that lunati sells is a link belt chain
Old Jan 24, 2006 | 10:37 AM
Internet Mechanic
my bad, I just caught that. Well if you want a roller, its time for a vented opti. I wish that would make a unvented opti sprocket
Old Jan 24, 2006 | 11:44 AM
TwoFast4Lv's Avatar
the LT4 extreme is a singal roller. You can get a Cloyes but it is not for a standard LTx water pump
Old Jan 24, 2006 | 12:30 PM
Internet Mechanic
WHen we say early LT1, this means the NON-vented opti. Its a different timing chain cover, optispark etc etc. LT4 uses a Vented opti and different cam sprocket
Old Jan 24, 2006 | 02:00 PM
d-marlo1's Avatar
yes, 92-95 uses a different cover and opti, I have found roller chains for 96 and 97 but not the early ones.
Old Jan 25, 2006 | 08:05 PM
Klortho's Avatar
'95 uses the same opti that the '96 and '97's do, the timing cover just doesn't have the spot for the crank sensor.
Old Jan 25, 2006 | 11:16 PM
BizZzatch350's Avatar
Moderator
Lunati makes one and so does Comp
Old Jan 26, 2006 | 01:21 AM
Nite_Hawk's Avatar
But, do you have to replace the Sprockets when you do the chain, or can you just buy the roller chain. Don't really feel like dropping almost 3bills on a timing chain.
Old Jan 26, 2006 | 09:15 AM
d-marlo1's Avatar
I found the one comp sells and it is $590.00
Old Jan 26, 2006 | 11:25 AM
stevemilz's Avatar
I used a Cloyes double roller and CSI water pump, its cheaper.
Old Jan 26, 2006 | 11:59 AM
lafnlt1's Avatar
i did the same thing, works great but you need a vented opti and cover
Internet Mechanic
Well.... you have a vented opti-spark, which in the aft-formentioned post it was asked was there an early LT1 roller timing chain.... early is non-vented opti.
Old Jan 26, 2006 | 01:07 PM
Nite_Hawk's Avatar
so, since i have a 97 i can just buy the Cloyes double roller and get an Electric water pump?
Old Jan 26, 2006 | 01:34 PM
Internet Mechanic
yeap, you also gotta close the WP hole, just incase.
Old Jan 26, 2006 | 01:51 PM
Nite_Hawk's Avatar
cool...have a friend in the machine shop on base, he owes me a favor.
