Scattershield?
Old Jan 25, 2006 | 04:11 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
Default Scattershield?
does anyone make a scattershield bellhousing for our cars??
Old Jan 26, 2006 | 12:22 AM
N20Dave's Avatar
No, not that's a bolt on anyway. I did it with the following.
I used the McLeod LS1 SFI bellhousing and had my input shaft shortened, used a viper front plate on the trans and an LS1 throwout bearing. McLeod makes a braided hydraulic line that adapts the LS1 hydraulics to the LT1 master. Next I used a twin disc McLeod from a standard 1986 and newer, one piece seal clutch assembly that is a conventional push style to mate with the LS1 throwout. The trans will sit about 1/2" further forward so a little massaging of the tunnel opening for the shifter is required. The driveshaft may also need to be lengthened.
I did it because I was having a new trans built by G-force and had the opportunity to make the changes at that point but if you're going fast and keeping a T-56 type trans, it's necessary in my opinion. Not just from a tech standpoint but from a keeping your lower limbs should anything come apart standpoint.
Old Jan 26, 2006 | 08:45 AM
CatchinZs's Avatar
Does anyone make a blanket that will work for the fbodys....or maybe one that will work for us.
Old Jan 26, 2006 | 08:53 AM
dhdenney's Avatar
I used to use that RCI blanket that you can buy in Summit and Jegs. PN 7808A. Didn't really provide any bellhousing protection IMO.
Old Jan 26, 2006 | 11:34 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
can someone make something like a plate, that can be bolted or riveted or whatever to the top of our bellhousing, so it would at least deflect any debris from the clutch.
Old Jan 26, 2006 | 01:44 PM
travie319's Avatar
http://www.stroudsafety.com/EngineSafety.html
call them and tell them what your looking for....
