Big Solid Roller, and my heads??
Old Jan 25, 2006 | 04:37 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
Default Big Solid Roller, and my heads??
i have 383 , I got 195 comp port AFR heads, comp 306 cam, ported lt4 manifold, hooker long tubes, etc etc.
this car has been sitting for a while and i have decided to go full drag car, but on a budget, i was wondering can go with a big solid roller cam, and still keep those heads and make decent power??, or do i need to change heads to make decent power? also if i go solid,what lifters pushrods and springs are the most popular, and how big of a cam should i go with, until i am reaching a point where i am not making that much more power.
Old Jan 25, 2006 | 08:13 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
anyone??
Old Jan 25, 2006 | 08:33 PM
chris77's Avatar
i would say go with bigger heads man i have the same heads on my 396 LT4 and they are whats holding me back, and with a solid roller you will have even more air going in and out thsoe heads.
Old Jan 26, 2006 | 02:54 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
yeah i am kinda on a budget, but which heads would you suggest??
Old Jan 26, 2006 | 08:50 AM
chris77's Avatar
then i would say to use the heads you got just get some who knows what there doing to do a nice port job on them, but if you could get new ones then i would go with the AFR 210's, or the LE3 heads.
Old Jan 26, 2006 | 09:29 AM
streetrod93's Avatar
i know here you could get a set of brand new LT4 AFR 210 competition port heads with port matched LT4 intake ready to bolt on if you're interested in that route.
Old Jan 26, 2006 | 11:25 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
well how much power will a 210 yield me over the 195's, i already have a lt4 manifold so i dont need that, i was looking into 227's??, or they not really a option
Old Jan 26, 2006 | 01:12 PM
JasonShort's Avatar
Moderator
Ryne, be careful where you get your information. Your AFR 195 castings are the same as the AFR 210 castings. The 210s just have more work to them.
I prefer the 210s over the 227s. If I were in your position right now, I would just have a little more work done to your heads, flow them, then give those numbers to Cam Motions and have them grind you a solid roller. With good tuning, your car will fly.
My solid roller 396 w/AFR 195s ported to ~211cc was trapping 126mph with a fairly small cam. That was before dyno tuning and running 17" rims on all 4 corners.
Sent you a PM as well.
Jason
Old Jan 26, 2006 | 01:34 PM
travie319's Avatar
Welcome Back....to The Lt1 Section!!!!! Lol....
Old Jan 26, 2006 | 01:37 PM
lafnlt1's Avatar
you should be fine, here is my cam specs, 264/270 @ .050" .631" lift w/110LSA
this is a huge solid roller and i only use a set of ported RGR stage II heads, these are LT1 cast heads, not LT4. i went 10.98 @125 with a super tight nitrous converter on horsepower only, no spay let. your AFRs flow more then these LT1 cast heads do.
Old Jan 26, 2006 | 10:33 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
thanks alot guys, i am going to look into more headwork, or possibly just going with a big solid roller, lots of decisions lol.
