LT1 engine build up at Exotic Performance Plus
Old Feb 6, 2006 | 12:12 AM
Eric Bazan's Avatar
Nice Set up for sure!
Good Luck With her,
Eric
Old Feb 6, 2006 | 04:57 AM
EPP's Avatar
EPP
Thanks, the engine goes back into the car today. Bob
Old Feb 11, 2006 | 05:07 AM
EPP's Avatar
EPP
I've added many more pic's. The car is up and running. We need to get some miles on it on our dyno so we can start tuning. Bob
Old Feb 11, 2006 | 07:44 AM
TwoFast4Lv's Avatar
I just noticed you are going to run a P1SC. Would a D1SC not be better for a 383 looking to get 14 Psi? Bonus is you could turn the Blower slower and make more reliable boost. Going to be pretty close the Termianl on the P1 trying to get enough volume to get 14 Psi with the P1 I would think?
I am just curios
Old Feb 11, 2006 | 08:01 AM
EPP's Avatar
EPP
Question
I am just curios
I'm not sure where you got the info that we are going to run a P-1SC on this engine. This engine may be seeing an ATI ProCharger in it's future, but not for now. Hopefully I don't have a P-1SC mentioned anywhere! We do have a P-1SC on our '95 Formula, though.
I certainly would use a D-1SC on this car. You are indeed correct that there is no way a P-1Sc would be able to feed this engine. Bob
Old Feb 11, 2006 | 11:40 AM
TwoFast4Lv's Avatar
My bad See what happens when you get up at 5am on a saturday and type. For some reason I could have sworen I saw P1SC
Old Feb 11, 2006 | 04:27 PM
EPP's Avatar
EPP
Smile
lol... You had me wondering if I didn't screw up my wording somewhere!!! I had to go back and reread what I had put in there. Thats what happens when I get up at 5am as well. Bob
Old Feb 14, 2006 | 05:12 AM
EPP's Avatar
EPP
This T/A is up and running. We'll post some dyno numbers as soon as we get the engine broken in. Bob
Old Mar 23, 2006 | 05:16 AM
EPP's Avatar
EPP
362 rwhp and almost 400 ft lbs of torque on untouched Trick Flow heads, N/A on a Mustang Chassis Dyno! I have the dyno graph posted at the link above. Bob
Old Mar 23, 2006 | 06:07 AM
Black97's Avatar
Untouched TFS Heads flow 250cfm something right? 362rwhp is great. What's the cam specs?
Old Mar 24, 2006 | 04:50 AM
EPP's Avatar
EPP
Smile
Yes, untouched heads, not sure what (I just woke up....) they flow. I'll get the cam spec's on the Comp cam we installed. Bob
Old Mar 27, 2006 | 01:35 AM
  #32
Blown383's Avatar
With that 383 did the Canton pan need to be clearanced?
-B
Old Mar 28, 2006 | 04:41 AM
  #33
EPP's Avatar
EPP
Smile
-B
I'll check with Brent to see if he had to clearance it, but I don't think he did. Bob
