LT1 engine build up at Exotic Performance Plus
What size combustion cambers did you get?
I have basically the same with probably a little bit better head, slightly bigger duration cam, Monoblade, and I have a D1SC plan on pushing 15lbs through a FMIC.
I have seen lt1's with stock heads hit clost to 500
i'd hook you up with a motor rebuild seriously.....i cant seem to find a good one where i live, truthfully no one thats messed with lt1's, thats what i want someone that knows what there doing thats the important thing.......... We were only seeing rwhp in the low 200 range, almost what these LT1 cars get bone stock!
Since when do LT1's get low 200's bone stock? I know guys that have hit 275-280 RWHP in their stock LT1's.
Edit: Missed your response. Got it now.
Naturally if you do the engine removal, rebuilding, and the reinstallation of the engine, you can save a lot of money.
We just recently finished a 383 LT1 in a one owners 192,000 mile '94 Corvette. With an ATI ProCharger at only 8 psi of boost, we made 475 rwhp on my Mustang Chassis Dyno. This engine should last another 192,000 miles with only 8 psi of boost. This would be 520 or so rwhp on a Dynojet dyno, well over 600hp at the engine. Bob
