Progress so far...
-Stock block, for now
-Advanced Induction LT1 head & intake street package and custom cam
-GM lifters
-CC push rods & 1.6 roller rockers
-SVO 30# injectors
-SLP adjustable fuel pressure regulator
-Meziere HP water pump
-Vented Optispark
-MSD coil
-Taylor wires
-PCM For Less update
-Kooks headers and dual cat Y pipe
-Goodyear high miler hoses
-Black ZR1 9 & 11 inch wheels, BFGDR’s out back
I’ll post pics of the heads and intake when I have them.
Kooks are going in a mine this month, probably have to rebuild my Ypipe or start from scratch because I love having dual 3" cutouts vs dual cats, but then again I like the idea of all stainless front to back with my existing Borla.
I'd really like to see someone do a dual 3" stainless exhaust, Borla XR1s with Borla tips, I'm looking for a good shop who can do mandrel bends and build this for me in Houston.
. Please let us know how the ypipe/headers all hang under the car when your done...thanks. Sorry, I haven't seen an email from you.
The cats on the KOOKS setup look pretty good, I doubt that they are much of a restriction. I'd like to pass NYS emissions.
I just got the camshaft and a few other parts from A.I. and with the snow coming here, I'll get it in. The heads and intake should be next week. I'm shooting for completion by March.
I'm getting it all together, I found an easy way to slip in those Kooks headers. Just pull off the heads and they'll pop right in.
The head studs worked out well and it looks nice too.
I should have it on the road in about 2 more weeks.
-The Kooks L/S header collector will not allow you to install an oil filter if you have the optional factory oil cooler. It looks like without the cooler adapter in place, you'll be able to get a standard filter to fit.
-The Kooks dual cat Y pipe comes quite close to fuel & brake lines in two places. My quick fix was to wrap the lines with some heat insulating cloth left over from wrapping the EGR tube.
I am in no way faulting Kooks. I've done some research and found that most F bodies don't have the oil cooler. As for the lines, well the Y pipe is pretty big and it snakes under the body where no exhaust pipe was designed to go.
The Kooks stuff is beautiful and was a perfect, spot on fit. I'm certain it'll perform as advertised and would certainly use it again and highly recommend them.
As for the "oil cooler." Nowhere on this site or others is there much information. I had disassembled my under hood plumbing outside at the start of winter and am now completing the job indoors. I was totally confused as to why one oil cooler line went to the water pump. Exhaustive research reveals that coolant, not oil, flows through these lines. This coolant cools the oil filter mounting base. Much detailed information was found on the WS6.com website.
I for one do not like this.
I'm removing this silly-assed system, installing a proper oil filter relocation kit, a real cooler at the radiator and a remote filter, probably in the area that the A.I.R pump stuff used to be.
I gave myself the day off (it’s good to be the boss!) to complete this mess.
To get around the oil filter/cooler adapter/header issues, I used a Canton billet remote oil filter adapter 22-592 and their billet remote spin on filter mount, 22-620. I installed the filter mount spaced over the ABS bracket so the filter hangs just behind the sway bar. Looks pretty cool too! There’s an Earl’s oil cooler pancaked on the AC condenser. #10 AN lines plumb the oil where it needs to be.
This pretty much buttoned it all up for now, it’s driveable. I took it out for a spin. I’ve been working on this car since early December and I had never drove a fourth gen before. This car kicks ***! Good pull, it spins them from a stop but from a dig of about 20 MPH or so, those big drag radials just hunker down and bite good. OOF-DAH!!
Speaking of the tires, the rears don’t seem to hit/rub anything. I did trim down the chassis snubbers and whacked in the inside of the wheel housings a bit. I think being stock height, I won’t have to worry about rolling the fender lips.
I don’t even know what kind of muffler is on this car but it sounds pretty nasty when I’m into it but pretty soft when just cruising along. I think I’ll keep it. Of course, a pair of ‘71 Monte SS tips will be on order soon.
Kudo’s to the boys at Advanced Induction for the heads, intake and cam. Good fellas!
What’s next? I’d like to setup a delay relay so the fans and water pump run for a short while after shutting down to reduce hot soak. The interior needs a carpet and one seat needs the leather repaired. The body could use some bangin’ and sprayin’, I’m not building another show car here, just a weekend cruiser.
Stay tuned!
Sorry for the funky colors, I need to find a better JPEG file reduction program.
I know, the rear suspension looks pretty ugly. With time & money, it'll have new componants.
It's a work in progress...
http://www.fookes.com/ezthumbs/
