'95 z28 problem starting...
Old Feb 14, 2006 | 05:59 PM
CaFFeineSouLja's Avatar
Default '95 z28 problem starting...
well I just recently bought a 95 z28 that had head gasket replaced and yesterday i went to the store and came back out and tried to start the car. It kept turning over and wouldn't start so i gave it a minute and then started up fine. Just went to work today and when i got to the parking lot the engine shut off and I tried turning it over and it wouldn't start. Pushed it into the parking spot and came back outside later and it started right up. Any ideas why it would be doing this?
Old Feb 14, 2006 | 06:18 PM
96formulaM6's Avatar
that sounds like what my car is doing,
Old Feb 14, 2006 | 06:25 PM
CodyB4C's Avatar
Mine was doing about the same thing. It ended up being a loose wire connection at the starter.
Old Feb 14, 2006 | 08:09 PM
have u put yours on a computer, mine was throwing out codes, like a mis fire, and o2 sensor, and egr valve.
Old Feb 14, 2006 | 08:47 PM
redhot lt-1's Avatar
i`ve had the same problem first turn it over it wouldn`t crank for the world hit it the second time fires right up a friend of mine is a ford man (poor soul) said he has seen it before and said he believes that it`s in the fuel system as it gets older the feul pump or regulator isn`t working up to par
