stroker head and cam package
Old Mar 5, 2006 | 07:07 PM
TransAmDave96's Avatar
Default stroker head and cam package
im researching 383 rotating assemblys and was wondering what a good head and cam package would be. my goal is 450+ at the wheels na. is anyone out there running a setup with those numbers who could clue me in? could i port and polish my stock heads enough to save a little cash? or would a set up like lloyd elliots le3 package get me to my goal? any help would be appriciated.
my car is a 96 ws6 6-speed, and headers
thanks in advance,
dave
Old Mar 5, 2006 | 07:21 PM
96capricemgr's Avatar
Advanced Induction and LLoyd Elliot will be two answers you will get a lot of and they should be able to help with stock heads.
Old Mar 5, 2006 | 08:03 PM
94greencamaro's Avatar
Advanced Induction is the **** when it comes to porting heads. They do the best work. Give Ron a call and he will talk you through what you need to achieve your goals. My heads and intake are with them right now.
Old Mar 5, 2006 | 08:07 PM
Speed Density's Avatar
hashtagBMW
www.advancedinduction.com
www.portpros.com
www.eportworks.com
Each company has pros and cons, a buddie of mine just sent his heads off to AI he is really excited to get em back.
Old Mar 5, 2006 | 08:14 PM
slagger's Avatar
i should get mine back from A I this week.
Ron is a cool person to work with
Old Mar 5, 2006 | 08:37 PM
wicked_95z's Avatar
its going to have to be a damn near perfect setup to get 450 at the wheels. I talked to both AI and LE and they both told me it would take a lot of work. THe right fuel setup, perfect valve lash and a good tuner. This is definitely not something you want to do yourself if you want to get close to 450
Old Mar 5, 2006 | 09:02 PM
Ditto. Im looking for around 400 for my setup. Just spray a little n20 man.
Old Mar 5, 2006 | 09:50 PM
TransAm6383's Avatar
LE is the man when it comes to making heads...
do you guys think the 383 set up is worth it? i mean if im going to rebuild it i might as well go big, but if im not looking to rebuild is it worth the $$$??
Old Mar 5, 2006 | 10:00 PM
If your going to rebuild it and set it up as an NA motor, i dont see any reason why not to go with a 383. Just a different crankshaft. Its not going to cost you a whole lot more and will give you a good gain over a NA 355.
