I pipe?
I really don't feel like getting a cut-out, but where would it "cut" anyway? I was just curious.
I'm not going to go that route though. It's too loud and I don't go to the track enough.
Also the cutout is placed best before the axle right under the backseat.
Paul
What is a good muffler for the price, with a noticable gain over the flowmaster? I guess if I change the size of the I-pipe, it won't fit on my flowmaster, will it?
By the way, the car ran an 8.4 in the 1/8 with that exhaust and an intake. So, I think I did something right. It can't be that restrictive.
wrong. it is quite possible to change size and retain the same flow (look up Bernoulli's principle). a change in pipe size will translate to a change in velocity, not flow. the same amount can flow past, just at a different speed. if you go to a smaller pipe, the velocity is obviously higher to maintain the same flow.
your idea of "the more flow in your exhaust, the more power" is also wrong, even if your first comment about flow actually had been correct. if your statements were correct then that would mean that the bigger the piping, the more power you could make. why not have 12" I-pipe or even an infinitely big one so that you could make infinite power?? please don't say that you need backpressure, because that's also wrong.
it's about "tuning" the exhaust to get the best effects. and just because you make more peak power, doesn't mean you will be faster. certain changes in exhaust correlate to certain changes in the power curve. there's plenty of information available out there on this subject so i'm not going to do a write up.
i'm not saying that you are wrong in telling him that he'd make more power, just that your explanation is.
you can pick up some peak power for sure by going to the 3" i-pipe, but i'm not going to say that you will have even a noticeable gain with it on the track. really, you have more to gain by going with a decent catback than just swapping out the intermediate pipe.
Even putting the stock muffler back on, which although it’s quiet actually doesn’t flow badly…
I’ve never heard a hooker aerochamber setup that I didn’t like (I just put one on my truck), and in most cases they flow almost as much as their maxflow, dynomax’s ultraflow welded and about the same as the magnaflows (magnaflows are a funny animal, I’ve seen them flow in the same range as some of the other straight through mufflers and I’ve seen them flow a little less, just like sometimes they sound great and sometimes they sound a little wimpy).
If you’re paying someone to put it on you might find that between the extra labor you’re going to be really close price wise with getting the whole hooker setup as you will be with just swapping the muffler, and for that matter, their stuff is pretty much a very simple bolt on, the hardest part will be getting what’s on there now off.
