Car still Breaking up in the upper RPM..
Old Mar 19, 2006 | 05:20 PM
Slw94LT1's Avatar
Default Car still Breaking up in the upper RPM..
Its making me mad about this been to the track this years and the car is only going 106-108 mph and breaking up and studdering from 5400 plus. I have replaced coil,plugs,coil wire,fuel pump what else is there, the opti was done about 3-4 years ago 20k miles ago that is the only thing left to do. Any ideas from you guys or input would be great
Old Mar 19, 2006 | 10:11 PM
96SCTA's Avatar
Could be a million differnt things. Can u get a log of a run to find out whats going on in there.
Old Mar 19, 2006 | 10:30 PM
MrBill97396's Avatar
injectors ?
Old Mar 20, 2006 | 10:45 AM
A-man930's Avatar
Try the ignition controll module, it's about $70, but it could be your problem. Try the throttle position sensor first though, it's only about $30. Good luck!
Old Mar 20, 2006 | 11:26 AM
detroit_903's Avatar
Default Re:
I had a similar problem. My car would start acting like yours in high rpms - It turned out to be a bad o2 sensor. Not sure if that's the problem or not but that's what caused mine to act up. Are you getting good gas mileage?
Old Mar 20, 2006 | 06:27 PM
Turbo_6's Avatar
If I knew nothing other than the car breaking up at high RPM's, I'd say that the order of likelihood would be: #1: Opti, #2: Opti, #3: Opti. Just my opinion though.
Old Mar 20, 2006 | 07:32 PM
-PEPE-'s Avatar
, what was causing my high rpm breakup, not to blame all bad things in life on the poor opti but it fixed my problem, 02 sensors were the next to go that helped on the overall stumble issue I shortly ran into after opti replacement.
Old Mar 21, 2006 | 09:52 PM
sdm1234's Avatar
bad fuel filter???
Old Mar 21, 2006 | 09:54 PM
WhiteSSP's Avatar
What is your battery voltage in the high RPM? If its low, it'll cause a miss.
Old Mar 21, 2006 | 10:07 PM
Billy the Great's Avatar
i had a very similar problem with my 383 when i installed it, ended up getting an MSD 6AL box and it went away. Might be something to try
