does ANYBODY sell the MSD billet opti???
If the stock lasted 143K why are you in such a rush to get something "better"? It is completely untested and it will be years before we really know if it is better. That said the cap and rotor appear pretty good and for the price I am trying them on my car, not installed yet though.
BTW, I can't imagine adjusting the advance on an opti with the engine running...could be kinda painful.
On the timing thing the ONLY right way to time a computerized car is through the pcm so the adjustable advance thing is of questionable "benifit" as well.
As I said I have a cap and rotor and they appear to be well made, I would even say the rotor appears it will solve the high rpm problems some had with the stocker, but to call it or the whole thing an upgrade at this point is irresponsible because they just are not well tested and proven yet.
How do you like your msd cap/rotor so far? I got my LTCC in Thursday, can't wait to get it on and excited about never doing another opti again.
As far as you never having to do an opti again this is exactly what drives me wild in these opti threads. Everyone loves to hate the opti and wants to "replace it", the thing is all the multi coil kits like the LTCC you are using replace are the cap and rotor, you still have to keep that horribly water sensitive housing the crappy small weak bearings and such. So how exactly are you replacing it? You are just taking voltage distribution duties away from it and still need a functional backhalf.
In all honesty, no one needs an upgraded opti. An upgraded cap and rotor like the MSD would be great to keep people from melting the rotor button when using stronger coils, or fighting off high RPM grenading and rotor screws coming loose. However the electronics work fine. It all comes down to the same thing that I say when someone complains that there opti only lasted 25K miles. You need to take care of it. If you let water and oil drip on it, it's going to stop working. If you neglect it for 100K miles, it's going to stop working.
The other thing that gets me, is that people will spend 400-600 bucks on a "better" opti, which doesn't address the fact that it's still being fed by a single coil set up. There is a reason that many man applications are running multiple coil or coil/cyl set ups. In all honesty, if your gong to spend 600 bucks on an opti, why would you not instead spend 500 on a multiple coil system and never have to worry about opti failure.
there are several people still using stock opti's on multi coil systems that have not had an opti failure in 5+ years. Take the high energy out of the equation, don't neglect oil leaks and water pumps, and you will probably never need to touch the opti again.
You will never se a $600 opti on my car. Instead you will see $400 worth of multi coil ign and a stock opti running it.
that and my opti lasted 10 years and 150k miles so far, and im keeping the opti just changing the cap and rotor
I will be using one and the main reason is the ability to alighn the Opti to a cam retard or advance. it DOES make a differance
Then again we DO know how to use it correctly so that may make a differance.I talked to a MSD rep just a few weeks ago at a trade show. Late March Early April they are going into production. They are waiting on parts.
He was also telling me last year the big hold up was because of the LS1 coils. they had such a huge resonse for them they were using alll the supplies for the Caps and Rotors (IE Red plastic)
Have fun all.
b) You have a good point about the marketing BS, I simply passed on what MSD is advertising to someone who asked the question. Far as that goes marketing BS in this hobby is just like the fishing lure industry, they build the lure to attract fishermen not fish
, damn largemouth bass gets hungry enough it'll latch on to your finger
. FYI ok wait... last week in our cost & schedule project staff meeting I did bash the opti...damn me to hell for that
. Well our software was acting up during month-end financials and the team was asking what could cause this..."due to a bad OPTI was my response"
....lot of blank stares
ensured
