Fastest Stock Internal LT1??
http://web.camaross.com/forums/showthread.php?t=440169
If not registered over there I will cut and paste.
If you want to know what the fasted run without anything IN the motor.. it is a STOCK MOTOR... not stock internals (well it is that too.. but it is compltly stock..) stock internals means rotating assembly.
Gotta head up to your shop sometime shon to discuss suspension
Above is the rules for Pure Street, Stock Internal LT1/LS1 for the F-Body Shootouts that I attend each year at MIR. RRs are allowed for LT1s and they still haven't found 11s yet. Shon's Z is a freakin monster, with or without RRs. He could win the class easily, but it's a good drive from SC to MD.
And for those that are being freaked out by the !interior, buddy just dropped off a full interior for me, so sometime (over summer probably) LW carpet and interior will be going back in.
are you not going to a 3 speed/big stall this year??
2006 goals were to put a new clutch disk in the car, that has been done. Set the bolt on record lower so that it would be hard to break, almost done. After the 11.80 run I know it will go into the 11.70's. Next goal was to practice until i could shift the gears like that....now I need more practice...if the practice does not produce the results I want then T-braked TH350 with 4k stall will go in and see what happens, it might be faster?!?!!?
whole forum dedicated, the next one is in June I think.
