Fastest Stock Internal LT1??
Old Mar 31, 2006 | 01:55 AM
The LT1 That Could's Avatar
Default Fastest Stock Internal LT1??
Trying to set a goal for myself....
I looked thru the ET Database list, but wanted to get some input in case things have changed....
What is the fastest a bone stock internal LT1 has gone.....boosted, sprayed, or N/A??
also, is there even a reason to try and go for fastest stock internal/stock suspension LT1, or does anyone even keep up with stock suspension setups??
I will have to go to a different track of course, with our average 5000' DAs here in Lubbock, but Houston could offer some great air.
Old Mar 31, 2006 | 07:16 AM
95z6spd's Avatar
I'm pretty sure the 6spd stock internal NA record is 12.48, the auto record I belive is 12.04...I dont know the bossted/spray records
Old Mar 31, 2006 | 08:08 AM
Shon Herron's Avatar
Let's clarify, bone stock being nothing done, as it came off the show room. Or are you talking about bolt ons with a stock motor?
Old Mar 31, 2006 | 09:52 AM
urbanhunter44's Avatar
It's high 11s. Like 11.9 I think. Lightened, full bolt on + tire car.
There was a thread about this not long ago, a quick search should find it.
Old Mar 31, 2006 | 09:53 AM
check my sig for the real answer.
Old Mar 31, 2006 | 10:07 AM
95z6spd's Avatar
The question was STOCK internal...ROcker arms dont qualify for stock internal by definition.
Old Mar 31, 2006 | 02:51 PM
I guess I should pull the RRs off and run the stockers and see how much difference it really makes, but guess is it would not be that much.
Old Mar 31, 2006 | 02:57 PM
MrBill97396's Avatar
Well there would be some change
Old Mar 31, 2006 | 03:03 PM
BizZzatch350's Avatar
Moderator
Fran's car is hitting 11.00s, valve covers never been off, bolt on LT1 with a lot gas and suspension
Old Mar 31, 2006 | 04:24 PM
Full suspension,9 inch,and like a 250 shot.
Old Mar 31, 2006 | 05:27 PM
95z6spd's Avatar
I bet you'll be in the 12's...they have to be worth atleast 2 tenths..especially with fresh tight springs...
Old Mar 31, 2006 | 08:59 PM
I doubt the RR are worth 2 tenths, i agree the springs are helpful.
Old Apr 1, 2006 | 01:21 AM
OutlawZ's Avatar
I ran 11.40 with a stock internal LT1 and a 150 shot.... car was 3500 lbs as well.... valve covers had never been off the car and even had a stock throttle body.... but i'm sure that had been beat.... AFAIK, someone in texas ran deep in the 10's with a stock internal setup like i had only he used an ignorant amount of juice to what equated to a banzai run.... trying to blow it up but it lasted a few passes...... think it was a 10.60 sumthin he ran....
Old Apr 1, 2006 | 02:56 AM
Well, I was close
What's your raceweight?
Old Apr 1, 2006 | 07:23 AM
Well, I was close
3100ish
Old Apr 1, 2006 | 02:30 PM
Moderator
He hit that on a 200 shot.
Old Apr 1, 2006 | 03:37 PM
Speed Density's Avatar
hashtagBMW
Anything that touches oil is internal.
A stock internal record would be mighty sweet to acheive.
Old Apr 1, 2006 | 08:17 PM
Not directed directly at you but it was posted.
the 'rules' are the rules, LT1's have accept the RR set up. The LSx'ers dont. I do not care. If that bothers you, then buy the LS1 and go for it.
Old Apr 2, 2006 | 12:28 AM
I consider rockers stock internal still. 11.80 is damn impressive. Would it be too much of a bother to ask for a full mods list shon? You can pm it if you want
Old Apr 2, 2006 | 07:52 AM
95z6spd's Avatar
LT1's have accepted RR's as "BOTL ON'S" ...never as stock internal. There is a difference. The reason why you see the Stock internal list on LS1's compared to a "bolt on" list for LT1's is because LS1's come from the factory with decent rockers( roller fulcrum) and the gain to be had with full rollers isnt that great compared to the ones on LT1's. With that..there are many more Stock internal LS1's then ones with bolt ons and full roller rockers. Shon you have the fastes BOLT ON LT1..it is known...But it isnt the fastest Stock internal LT1
