LE3 cam & LE2 heads .......
Sorry about the hijack. Lloyd recommended the Imp head gasket for my setup. That will put you close to the range you are looking since the deck height on your bottom end is stock. I will run the numbers for you tonight
You will see my video on there, its LE 3 heads with Brets 2.2 cam. Stock bottom end.
Thanks for that link. Tons of great videos on there.
