Did a little turbo fabbing last night...
Old 04-08-2006, 02:33 PM
Dragframe's Avatar
good job on the merge... looks real good... and everything looks like it should fit... tight... but fit in snug and look good. Also with the turbo down there people wont pop the hood and see that they are in trouble right away. lol
Old 04-08-2006, 09:28 PM
RealQuick's Avatar
Originally Posted by garth285
would this fit in like a stock engine bay or would it have to kinda a race set up....Im intrested in some forced induction but I dont wanna take to much off the front end?
It will fit in front in a stock engine bay as long as you dont mind losing A/C and if you dont mind buying a set of pusher fans to put on the other side of the radiator (must eliminate stock fans for clearance).
Old 04-08-2006, 09:34 PM
LookinAtMyPlate's Avatar
looks great man!
Old 04-08-2006, 09:46 PM
RealQuick's Avatar
Thanks guys.
Old 04-09-2006, 10:14 AM
garth285's Avatar
not to bad than, no way aroudn not loosing a/c though huh, cant clear it anyways on the left side?
Old 04-09-2006, 12:11 PM
Dragframe's Avatar
you COULD run a manifold that is mounted "correctly" and have a pipe come from the back of the motor to the front. Wouldn't be as clean. Plus you would have a lot of fun running pipes or you could do it the easy way and go under the cross member (lose LOTS of ground clearence).
Im ditching a/c in my setup. I figure i got windows and t-tops. If it gets hot go faster with the windows down and tops off. lol.
Old 04-10-2006, 07:41 AM
RealQuick's Avatar
Like Nick said, the outlet of the manifold could be near he firewall and the pipe could run under the motor mount to the front. Here is the problem though:
I switched the pass. manifold to the driver's side so the outlet is up front and wil clear the steering shaft. This means I only have one manifold left (the dr's side now on the passenger side). With the dr's side on the pass. side the outlet is toward the front.
Have big power for cheap or keep AC???? Its preference I think.
Quick Reply: Did a little turbo fabbing last night...
