LT1 Granatelli 85 MAF
Old 04-11-2006 | 12:47 AM
burnzilla's Avatar
Default LT1 Granatelli 85 MAF
http://www.granatellimotorsports.com...automotive.htm
•Direct OEM replacement, won't void your factory warranty
•Improves mileage and throttle response
•Chassis dyno proven to add 8-25 horsepower (depending on application), 60% airflow increase over stock
•Improves performance from 2,000 rpm to red line
^^^ Is this bullshit?
How will they work with a CAI, and Exhaust?
Can you really get 10hp, or more from these?
Old 04-11-2006 | 02:36 AM
infinitebird's Avatar
Do not get it. It will screw up your tune. Yes you may get an initial increase in hp, but it's only for a temporary period because it's causing the engine to run leaner than normal. The computer will eventually figure this out and adjust fuel trims and then the power will return to what it was.
Just leave the maf stock unless you have good reason to change it.
Old 04-11-2006 | 06:29 AM
ss97dml's Avatar
Junk!!!
Old 04-11-2006 | 08:54 AM
WhiteSSP's Avatar
Yes Its bullshit. Jst an FYI, I went from a Granatelli to a Stock MAF, and went from a 14.1@100 to a 13.5@104.
Old 04-11-2006 | 09:45 AM
silverlt1ss's Avatar
keep the stocker, i had a granatelli and it was great at first then it started acting up. the idle was shittie and the car would backfire after i left off the gas at wot. i switched the ends from the grantelli to the stock MAF and gained 4 10ths in the 1/4. how bout them apples
Old 04-11-2006 | 01:53 PM
burnzilla's Avatar
What would I do without you guys?
When you can email a beer, let me know, cause I owe you all one.
Old 04-11-2006 | 02:40 PM
BGImportkiller's Avatar
I had one and it was fine, but if you get a tunem the tune won't be as good because they cannot adjust the mapping for that maf like they can for the stocker. So what increases it may give you, you will give back in the tune. Thats why I sold mine and went back to the stocker.
Old 04-12-2006 | 12:32 PM
Priest's Avatar
BGImportkiller, how are those mods you got working for you?
Old 04-12-2006 | 04:43 PM
I'll PM you, cause I don't wanna jack this thread
Quick Reply: LT1 Granatelli 85 MAF
