need some help with some problems
Old Apr 15, 2006 | 09:34 PM
slolt1's Avatar
Default need some help with some problems
i am unsure of what is going wrong maybee some one could help me out if i can describe the problem but it is like it runs out of fuel or looses ignition it dont do it all the time and is mostly while just at a steedy rpm then ecelerate slowly it will just fall like you cut the switch off if you pick up off the gas pedal it stops almost like the fuel drowns the engine out and if you pat the gas when it does it some times you can here it pop back through the intake it has completly shut off once before but i t started right back up i have already repl the opti,coil,and wires and plugs the fuel pump is haolding a steedy 43.5 i instaled it probly last year its the walbro 255 oh andthe check engine light doesnt come on any sugestions will be great if you have any thanks
Old Apr 16, 2006 | 01:55 AM
RUNINHOT's Avatar
I have the same problem right now also. My local mechanic has not figured out what the deal is yet though. Not much $ for them to keep looking for the prob. so if anyone has any ideas please chime in
Old Apr 16, 2006 | 11:06 AM
slolt1's Avatar
i am putting this up again somebody has had this problem and found what is going wrong and if i find it i will be sure to let you know
Old Apr 16, 2006 | 09:56 PM
slolt1's Avatar
any body
Old Apr 17, 2006 | 06:17 PM
slolt1's Avatar
ok i gues nobody has had this problem jut the two cars here maybe we can find out whats up
Old Apr 22, 2006 | 12:36 AM
Quick LT1's Avatar
I have the same problem at the moment,it quit doing it for about a week now its starting to do it again,sometimes it does it while going down the road.Also sometimes while Im driving it will just lose power, the motor will still be running tach will still be working and all,Feels identical to a car that has hit its speed limiter.Also when it dies at idle sometimes its hard to crank but if I let it sit for about 10 seconds or so and let the fuel pump kick on it will start up just fine.
Old Apr 22, 2006 | 01:00 AM
RUNINHOT's Avatar
I have been working on this prob for about 3 weeks now. No luck yet with mine. Going to be checking the egr system tommorow though. Suck that my car is no longer dependable to drive.
Old Apr 22, 2006 | 05:31 PM
slolt1's Avatar
i doubt it has any thing to do with egr becouse mine has been completely removed and tune out in the computer
Old Apr 23, 2006 | 10:59 PM
RUNINHOT's Avatar
Does anyone else have a misfire code that poped up.
Old Apr 23, 2006 | 11:14 PM
ujslost2's Avatar
I used to have a 93 Trans Am that this exact same problem happened on. I replaced what they called a ignition control module. It is right above the coil pack. Its the sensor that has a plug going to it. I got mine at autozone for 40 bucks. I hope this helps.
Old Apr 24, 2006 | 07:21 PM
RUNINHOT's Avatar
Thanks for the input on the problems. I think I will try that tonight.
Old Apr 24, 2006 | 07:30 PM
slolt1's Avatar
hey autozone has it for 80.00 that shopuld get you fixed
Old Apr 24, 2006 | 10:08 PM
RUNINHOT's Avatar
Nope just put one on and it did NOT work. But now instead of compleatly cutting out it only sounds like a couple of the cylinders are cutting out now. Not going to mess with it anymore tonight. why wont you run
Old Apr 25, 2006 | 05:13 PM
slolt1's Avatar
did youi put any white grease in between the module and bracket the module cant ground the grease keeps that from hapennuing
Old Apr 25, 2006 | 06:51 PM
RUNINHOT's Avatar
Nope, didnt do that. When I put everthing back togther I will try that.
Old Apr 25, 2006 | 07:06 PM
slolt1's Avatar
yes that could verry wel be the problem i think the grease is white lithium grease just put a good cover over the back of the module then you should be good let me know though
Old Apr 25, 2006 | 07:12 PM
slamm69's Avatar
I had the same problem and it was the ICM.Changed it and now everything is fine but it caused me pure hell finding that bug..
