boltons???
Old May 3, 2006 | 08:37 AM
chameleongreen97ta's Avatar
Default boltons???
what in the hell do you guys mean when you talk about a 10 bolton car or a 12 bolton on car. elborate for me i have a very limited knowledge about cars
Old May 3, 2006 | 08:48 AM
AWS-Z28's Avatar
I think you are referring to the type of rear end that the car has. 10 bolt is the stock rear end and a 12 bolt is aftermarket and much stronger.
Old May 3, 2006 | 09:42 AM
the_merv's Avatar
Veteran: Air Force
To tell, you look at the rear Cover on the Differential and count the bolts. 10-10 bolt, 12-12 bolt.
Old May 3, 2006 | 10:35 AM
Captainofiron's Avatar
That is not true.
Its the number of bolts on the ring that attaches it to the differential carrier
Old May 3, 2006 | 11:09 AM
the_merv's Avatar
Veteran: Air Force
I know that, I was telling the shortcut to tell, without pulling the ***-end out of the car. And it has worked on every Chevy that I have torn apart...
Old May 3, 2006 | 12:00 PM
ToxicFormula's Avatar
and a 9 inch won't have any rear cover bolts
Old May 3, 2006 | 12:05 PM
the_merv's Avatar
Veteran: Air Force
That is Ford for you, everything is hidden...
Old May 3, 2006 | 02:40 PM
93BlackZ's Avatar
thats for sure, if youve got an M6 put that 9" on there, A4 go with a 12 bolt, or grenade the 10 bolt then decide what you wanna do
Old May 3, 2006 | 03:14 PM
red95ssclone's Avatar
"How does the posi-track rear end on a hemi work.........................I dunno, just does"
Old May 3, 2006 | 03:24 PM
93BlackZ's Avatar
good ole' joe dirt
