Codes
Old May 7, 2006 | 03:50 AM
RedRocketLT1's Avatar
Default Codes
Can you use the paperclip trick on 97 TA. I've seen posts about doing it on an LT1, but the ALDL looks different. The A and B terminals aren't used.
Old May 7, 2006 | 04:14 AM
Honda Hunter's Avatar
No. I thought that was a obd1 trick that only worked on 93's?
Old May 7, 2006 | 04:18 AM
I guess so if the 93's were odb1
Old May 7, 2006 | 09:01 AM
4ced's Avatar
the 94 camaros are odb1... can it be done on those
Old May 7, 2006 | 11:29 AM
CULATR's Avatar
ok what the paper clip trick???
Old May 7, 2006 | 04:46 PM
It's when you stick both ends of a paperclip or anything that with complete the circuit between the A and B temrinals on the ALDL under the dash. Then turn the key without starting and the SRS light will flash so many times and give you any codes the ECU has stored.
