**Need help (383 Stroker Kit)**
Old May 23, 2006 | 02:44 PM
mumu_624's Avatar
Default **Need help (383 Stroker Kit)**
hey Im fixing on to get a 383 Stoker kit on My 95 Trans am....
Would this fit????
does it need anything else for it to work?
http://cgi.ebay.com/ebaymotors/Crank...QQcmdZViewItem
Old May 23, 2006 | 04:49 PM
DeltaT's Avatar
Just out of curiousity, why aren't you upgrading to forged pistons? That way you'll be set for a power adder at some future point.
As a kit, it's pretty complete, but I don't think it will work because you should have a 1-piece rear seal and this crank is set up for the older style 2-piece. You would have to run an adapter.
If you go that route, you should have the rotating assembly balanced - see if the assembly can be internally balanced. You'll have to clearance your block for the stroker crank.
Just some quick thoughts.
Jim
Old May 23, 2006 | 06:34 PM
streetwarrior96's Avatar
better go forged !!!!!!!!!!!!!!!!!!!!!!
Old May 23, 2006 | 07:17 PM
camaroz2866's Avatar
Scammer Alert!
exactly...lt1's have the "early" style 1 piece rear main and are internally balanced not externally
Old May 23, 2006 | 07:24 PM
Flores96TA's Avatar
No it will not work.Do some more research on kits for that LT1. www.strokerkits.com look for 1piece seal for LT1's. O and get a good balanced kit cause I tried to get one of the kits off of ebay and I had hell getting the right one.
