Snapped header bolt help
Then use a Sears or equivalent bolt extractor. You'll need a carbide drill bit (at least - don't know how hard your factory bolts are) to drill the hole then thread the extractor in COUNTER clockwise until it grabs, then try to slowly put greater pressure on in, nice and straight, until it breaks loose and back it out. Use the proper size thread chaser to clean the threads.
I agree with Buffman about the Earl's Pressure Masters. They work great and the graphite inserts are available seperately - get an extra set when you buy the gasket set - surely you will need one when it's 2 in the morning sometime!
Jim
